Is microprocessor an integrated circuit???
Y
yogesh
regards,
ypj
F
Fred Bloggs
regards,
ypj
Get lost!- and don't post to this newsgroup again.
M
Mark Jones
Jamie said:
oh have a heart! :/
Yogesh might be a 5-year-old boy... we don't know. That's the thing
about google-groups - anyone can post there - they don't have to be
old-school, professional usenet denziens like us. Play nice, Fred! :)
Yogesh should go to ibiblio.org/obp/electricCircuits/ and learn some
basics there. That ought to keep him busy for awhile.
B
Bradley1234
Answer: it can be. Some microprocessors are made with discrete components,
but most today are integrated circuits, meaning the components have been
built onto one circuit
Microprocessor means: micro programmed processor such that instructions are
processed by referencing internal memory locations and there is a processor
within a processor.
Most commercial microprocessors are general purpose, meaning the instruction
set gives developers methods to move/control data, but some uPs are specific
and have a limited/specific instruction set
K
Keith Williams
within a processor.
Yikes!
T
TCS
within a processor.
No it doesn't. It means micro-sized processor. What you're describing also
includes the vax-11/780 whose processor board was hardly a microprocessor.
A microprocessor is nearly always a single chip processor; first one was the
4004; following were the 8080, 6800, 1802, etc. I don't bit slice processors
could be considered a microprocessor.
T
TCS
and by the way, most 8 bit microprocessors weren't microprogrammed. Their
instructions units were hard wired.
B
Bradley1234
Yes, the 11/780 cpu was a microprocessor. Who on earth came up with micro
sized processor? Why not micro stereotypical processor?
no, the first commercially sold IC microprocessor was the 4004, but there
was one built for a dumb terminal that predates it. Bit slice are
microprocessors, why wouldnt they be?
B
Bradley1234
microprocessor.
You will want to revise the last sentence.
The instruction units were hard wired with... microprogramming. The
instruction is fetched and what happens? it references a memory inside the
cpu, a processor within a processor running micro code
K
Keith Williams
Nope. No microprogramming. The logic was hard wired. No control-
store, no microprogramming. Not all processors are microcoded.
K
Keith Williams
What color is the sky on your planet?
Simple answer; Because they're not single-chip.
Microprocessor == single chip processor.
T
TCS
BULLSHIT. The 11/780 was a minicomputer.
B
Bradley1234
TCS said:
No they weren't. They were hardwired via logic.
This is simply not accurate. Microprocessors typically operate with
instruction and data fetch modes. When an instruction fetch takes place,
the op code causes a branch to an internal memory of the internal cpu state
machine, running on an internal clock. This sets off a process where the
data portion of the instruction or subsequent fetches or registers are used
to manipulate data, or they set some status within the cpu state machine
There is no simple hardwired logic, there is a stored program, a
"microprogram" within the cpu that will "crack" the instruction like a
walnut and see whats inside and eat it if its fresh.
Microinstructions can be 100 bits wide, or for an 8-bit? I dont recall maybe
something like 43 bits wide, it depends.
When there is a micro engine, using micro instructions, stored in microcode
memory, its a micro processor. There is a clock, internal microcode address
generator, next address logic, mux. Can you name any 8 bit cpu that uses
only hard wired logic??
T
TCS
Which is irrelevent to wether or not a processor is microcoded.
again, irrelevent.
There is no simple hardwired logic, there is a stored program, a wrong.
Or it can be done with combinational logic.
or not at all.
Some microprocessors have a microcoded instruction decoder. So do some
minicomputers.
T
TCS
TCS said:
The system would be a "minicomputer" some want to say its a mainframe. But
I specifically wrote that the 11/780 "CPU" was a microprocessor because it
executes an internal stored microcode processor
You can post that it is a can of grapes, but that doesn't make it so.
The vax-11/780 was not a microprocessor. Using microcode does not make a
microprocessor.
There are many examples of microprocessors that didn't use microcode.
