Is It SOP to Use TO-220 ..
  • Thread starter Watson A.Name - \Watt Sun, the Dark Remover\
  • Start date
W
Is it SOP to use TO-220 mounting hardware for TO-126 packages?
Thanks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
T
Tim Shoppa
I thought that TO-126 packages have a hole sized for 3mm metric screws,
while TO-220's have holes sized for 6-32 (non-metric) screws.
You will not be able to put a 6-32 screw in a TO-126!
All of the associated insulator hardware (mica sheet, fiber or nylon
shoulder washers,etc. ) for TO-220's is completely unnecessary for a
TO-126, right?
Tim.
W
TO-126, right?
Tim.
Maybe I shouldn'r have said mounting hardware, I really meant mica
insulator and washer and hardware (of the appropriate size), like what
you get when you buy a TO-220 mounting kit from Rat Shack.
I've seen TO-126 devices (mostly Japanese) mounted directly to a steel
heatsink which is soldered to the PC board. I've seen 'em mounted to
the PC board for low power apps, with a clip-on HS, or even freestanding
w/o a heatsink. But I've never seen 'em mounted to a HS with a mica or
other insulator.
The On Semi AN-1040/D shows 'em mounted to a HS with screw and nut and a
conical washer, but no mica insulator. That's fine if you use an
electrically isolated heatsink. But if you want to mount them to a
chassis or bigger heatsink, say as driver transistors with the output
trs on a common HS, then they have to be insulated.
I've seen several TO-220s mounted to a common HS with the gray rubbery
thermopad insulators and an aluminum bar across them all to hold them to
the HS. That way, there's no hassle with insulated washers, bushings,
or screws. But I've never seen the TO-126 with mica insulator and white
silicon goop. So I'm just trying to come up with some kind of solution.
Thanks.
F
Fred Bartoli
other insulator.
Thanks.
Why wouldn't you do it? Just because you've never seen it before?
Just check the mica hole size against the TO126 hole isolation and go for it
if it's OK.
W
Walter Harley
[...} That's fine if you use an
The TO-126 transistors I use (BD135, BD136) are completely insulated. What
TO-126 transistors are you using, that have exposed metal like a TO-220?
W
Walter Harley said:
in message news:[email protected]...
TO-220?
No, the BD135 has the flat metal area on the back, which contacts the
heatsink, electrically tied to the center pin which is the collector.
The BD135s I have are made by Philips. The same is true for the 2SD975.
However the 2SC4934 is completely encapsulated in plastic and is
electrically isolated from the heatsink.
See datasheet here
http://www.semiconductors.philips.com/pip/BD135_137_139_3.html
W
"Fred Bartoli"
"Watson A.Name - "Watt Sun, the Dark Remover"" <[email protected]> a
écrit dans le message de
My original Q was "Is it SOP (standard operating procedure) to use
TO-220 mounting hardware for TO-126 devices?"
if it's OK.
E
ehsjr
other insulator.
Thanks.
TO-220: Use a sil-pad (the gray rubbery thermopad you mentioned),
incur the wrath of John Larkin (rightly so, as experiments
demonstrated), endure more heat in the device - but if you need
insulation... mica would be better, sil-pad easier to modify (if needed).
I haven't experimented yet to see the Rt difference between
a sil-pad and mica. I've never seen a TO-3 sil-pad, but
TO-3 micas abound. Makes you wonder. Mica is supposed to
be a better heat conductor than sil-pad.
Ed
W
[snip]
Ed
I've seen the spacer, looks like it may be anodized aluminum, for the
TO-3. It's thicker than mica, and dark, almost black. I don't know
what it's made of, because I've never had to remove one. Seems like all
the PSes I've come across are cheapo, with TO-220 or similar devices.
It used to be that heatsinks were massive with convection cooling and
TO-3s. Nowadays in order to reduce size and weight and cost, they are
all smaller and cooled with fans and use epoxy cased devices.
The On Semi AN-1040/D app note shows some good info on why the TO-220
and similar are not the best way to mount a power device to a heatsink.
W
Walter Harley
See datasheet here
Hmm, interesting. The BD135s I've been using are by Fairchild, and they are
completely insulated, no exposed metal.
http://www.fairchildsemi.com/ds/BD/BD135.pdf
What a pain! I don't think I've seen mica insulators with the smaller
TO126-sized hole myself, although Google does turn some up ("TO126
insulator").
W
See datasheet here
insulator").
The Fairchild datasheet I have is dated Feb 2000 and doesn't show
whether or not the 'backside' is insulated; it doesn't show the
backside. Philips' datasheet does so and states so. SGS-Thomson's
datasheet calls the package SOT-32, and does show a graphic of the
backside, which looks like it has a metallic area that contacts the
heatsink. But it doesn't state that it is connected to the collector.
The general standard is that most transistor packages have the metallic
area electrically connected to the collector.
ON Semi has the BD135 and says it's in the Case 77-09, what it calls
TO-225. Here
http://www.onsemi.com/pub/Collateral/BD135-D.PDF it shows the metallic
heatsink contact area, but doesn't state that it is electrically
Fairchild's BD135 series should conform to the rest of the industry,
which is probably like Philips, since Philips or another Euro
manufacturer is probably the original maker of the series. Also it
seems to me that in order to dissipate that much power on a heatsink, it
would have to have a metallic area on the backside.
