Is it possible to multiply resistance?
Discussion in 'Electronic Basics' started by randomname, Aug 25, 2006.
  1. randomname
    randomname Guest
    I know resistors in series simply add up... but is there any way to
    mulitply resistance?
    eg: can I take a 10k pot and make it work as if it were a 100k pot?
    -sam
  2. Don McKenzie
    Don McKenzie Guest
    in a word, NO
    Don...
    Don McKenzie
    E-Mail Contact Page: http://www.dontronics.com/e-mail.html
    Micro,TTL,USB to 1.5" color LCD http://www.dontronics.com/micro-lcd.html
    USB,RS232 or TTL to VGA Monitor http://www.dontronics.com/micro-vga.html
    World's smallest USB 2 TTL Conv http://www.dontronics.com/micro-usb.html
  3. John Fields
    John Fields Guest
    Sure.
    You could use a 10k pot to drive a servo which would turn the 100k
    pot degree for degree with the 10k pot.
    What do you have in mind?
  4. phaeton
    phaeton Guest
    Or even using the 10k to control a 100k digital pot? Or even just a
    FET?
    -phaeton
  5. randomname
    randomname Guest
    well im still dwelling over what a 555 timer can do. id like to have 2
    pots... 1 to adjust the duty cycle (without changing the frequency),
    and another to adjust the frequency.
    -sam
  6. Jamie
    Jamie Guest
    the pot could bias a MosFet to be used as a v-r.
  7. John Fields
    John Fields Guest
  8. randomname
    randomname Guest
    absolutely!
    thanks,
    -sam
