is it possible to measure the magnetic flux / magnetic field from a laser? tia sal2
Discussion in 'Electronic Basics' started by temp, Sep 6, 2007.
  1. temp
    temp Guest
    Greets All
    is it possible to measure the magnetic flux / magnetic field from a laser? If so what type of equipment would I need?
    tia sal2
  2. Tim Wescott
    Tim Wescott Guest
    At the dimensions where such measurements would be useful to know you'd
    be working in a big physics lab, measuring really tiny things. You'll
    get a much more accurate measure by measuring the level of coherence and
    the intensity of the light, and calculating the magnetic field strength.
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
