DongBeetle
- Jul 5, 2012
- 2
- Joined
- Jul 5, 2012
- Messages
- 2
Hi all, new to this forum..
I'm in the process of building a small 3 phase alternator, consisting of 6 coils and 8 magnets, the wire I'm using is 0.3mm and each coil is just about 675 turns (1350 turns and 80 meters of wire pr. phase)
The thing is, there's about 20,3 Ohm's thru each phase, and that seems high to me,
so.. is that good or bad in an alternator/generator?
And what about heat, is that likely to be a problem? (I do plan to encapsulate it)
Also, I've tried to figure out how to make a switch hookup to switch between 'star' and 'delta' configuretion, can you tell me if what I've come up with is right and will work!?
Regards.
Regards.
