Is DVI really digital?
Discussion in 'Hobby Electronics' started by Michael Culley, Jul 7, 2004.
  1. I thought the old VGA plug on a video card was analog and the new DVI was completely digitial. But if that is the case why is it so
    easy to convert DVI into VGA (with a $15 adaptor). I suspect it is just VGA with some extra control signals, is this true?
    Cheers,
    Michael Culley
  2. Thanks, that answers my question. For anyone reading this it looks like DVI is completely digital but has pins that are analog for
    backwards compatibility only. A DVI monitor will use the digital pins while an analog monitor will use the analog pins, which is why
    it is so easy to 'convert' from DVI to VGA. Not all DVI video cards have the analog pins although most do now.
  3. Andrew
    Andrew Guest
  4. Alex Gibson
    Alex Gibson Guest
    Which DVI ?
    There is
    DVI-A analog
    DVI-I analog and digital
    DVI-D digital
    http://www.webopedia.com/TERM/D/DVI.html
    http://www.datapro.net/techinfo/dvi_info.html has pictures of the
    connectors
    Alex
  5. Alex
    Alex Guest
    An interesting fact I leant recently was that the 15 pin sub-d
    connector used in normal analog VGA cables isn't actually designed to
    carry the frequencies used by VGA. The DVI connector, OTOH, is.
    So you're slightly better off using the DVI connection even if your
    monitor is analog. Assuming it has one, of course.
    Whether anyone could tell the difference is another matter..
    Cheers,
    Alex.
    Ernie and bert don't live in my email address.
