IRFP064 gets burnt
Discussion in 'Troubleshooting and Repair' started by xyz9915, Dec 31, 2008.
  1. xyz9915
    xyz9915
    Dec 31, 2008
    Please view the attachment of SMPS circuit which was modified by me to fulfill my requirements. I made three PCB's of the above SMPS (Output about 220V/1.5A DC). The problem is that one PCB is working fine and delivering my desired voltage & current (i.e. 220V/1.5A DC). But in the remaining two PCB's, power MOSFET (IRFP064) gets burnt within 2-3 minutes.
    My question is that when the three PCB's are identical, so why one board is working satisfactorily & other two boards are not functioning properly? I thoroughly checked everything in all PCB's but remained unsuccessful. Hence please help in this respect.
    Further another question is that can I use power transistors (e.g TIP35) despite using MOSFET's? By providing sufficient driving to the transistors?
    Note: The IC is TL494
    Best regards
    • 3-C.zip
      File size:
      74.2 KB
      129
