P
Pooh Bear
Hi all,
I'm using an IR2110 high and low side gate driver in a smps that I
mentioned some time back in the group under the thread 'should I use a
SG3525'.
I've had some 'odd' power device failures that I didn't expect in
entirely benign situations, such as the half bridge output simply
driving the primary of my transformer.
I realised that it happened a couple of times when I wound down the
input volts ( I'm supplying the board via a variac and isolating
transfomer for development ).
The IR2110 has undervoltage lockout. Fine ! I checked it carefully today
and the UVLO for the low side and high side aren't linked. Indeed a
careful look at the data sheet does indeed show that there's no
connection. The low side drive activates at about 8V and the high side
about a volt higher.
Needless to say this creates 'issues' !
Anyone here used this part and care to comment ?
Regds, Graham
SG3525'.
Regds, Graham
