IR trans-rec
Discussion in 'General Electronics Discussion' started by DavidV, Dec 26, 2018.
  1. DavidV
    DavidV
    16
    Dec 5, 2017
    I am working with some of my students on a Science Olympiad project. Electronics beyord resistors and capacitors is not my strong point. I am looking for a simple IR transmitter- receiver combo. We can use a standard TV remote but that would take up a lot of space. I looked through a box of parts left behind by the previous physics teacher and I have some of these https://www.amazon.com/Digital-Receiver-Transmitter-Arduino-Compatible/dp/B01E20VQD8.
    Can someone provide a simple circuit diagram that a novice might be able to follow that will allow this to act as a simple switch. I also have some relays https://www.amazon.com/gp/product/B00VRUAHLE/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 lying around.
    I don't have any transistors but can order some if I know what to get.
    If these parts aren't usefull let me know what to buy and if I can get all the parts for under $20 I can order them.
    All I need is to use an IR beam to be dectected 20cm away which then turns something on. Only constraint is max 9V and we have limited overall size for the entire device.
  2. Bluejets
    Bluejets
    5,027
    1,048
    Oct 5, 2014
    Those particular units are modulated signal and will require a microcontroller such as an Arduino with appropriate code to work.
  3. DavidV
    DavidV
    16
    Dec 5, 2017
  4. BobK
    7,682
    1,688
    You have not told us what you want to do with an IR transmitter and receiver. You might be talking about sending data a mile away, or you might be talking about detecting when a sheet of paper is in place in a printer. Both of these are done with IR. So what is it you expect to do, in detail.
  5. DavidV
    DavidV
    16
    Dec 5, 2017
    "You have not told us what you want to do with an IR transmitter and receiver."
    Sorry, I may not have been clear. In my original post I wrote all it needed to do was "to act as a simple switch" and "All I need is to use an IR beam to be dectected 20cm away which then turns something on."
    We need to turn on the transmitter and have it trigger the receiver which closes a circuit and stays on and allows a voltage or current. It will not to stay on. I can connect it to a transformer.
  6. BobK
    7,682
    1,688
    Okay then, a simple IR LED and phototransistor will work then, driving either a relay or a more powerful transistor.
    However, ambient light is still a consideration. You may need to put the detector insude a tube looking directly toward the LED, shielding it from extraneous light.
    DavidV likes this.
  7. DavidV
    DavidV
    16
    Dec 5, 2017
    Would these do the trick?
    https://www.amazon.com/gp/product/B00EFOQEUM/ref=ask_ql_qh_dp_hza
    Connected to something like this?
    https://www.ebay.com/p/Tolako-5v-Re...-1-Channel/1963275315?iid=253993010146&chn=ps
    Would a simple circuit be enough? I would a switch to the transitter circuit to turn it on. Also add a relay to the receiver circuit.
    [​IMG]
  8. Bluejets
    Bluejets
    5,027
    1,048
    Oct 5, 2014
  9. BobK
    7,682
    1,688
    No, those are 38KHz receivers that require a lot of active electronics to use, typically a microcontroller.
    Stop looking for IR transmitters and receivers and look for what I suggested:
    IR LED and
    Phototransistor
  10. DavidV
    DavidV
    16
    Dec 5, 2017
    Could you be specific? Everytime I look up what you suggest I get items similar to what I linked.
    Are you suggesting something like a BPX38 or BPW76A/B?
    And SFH 4855?
  11. BobK
    7,682
    1,688
  12. Bluejets
    Bluejets
    5,027
    1,048
    Oct 5, 2014
