A
Alan Rutlidge
Looking for a source of supply for a small dark red sensor cover for an IR
receiver similar to that used on a lot of commercial equipment.
The IR module is mounted behind an aluminium panel with a 5mm round hole
drilled through it to allow the IR signals to pass through it.
What I need is a suitable small "window" or sensor cover to provide a
finished look to the product. The hole can be made larger to accommodate a
bigger cover if necessary.
Anyone sells these?
Alan
Anyone sells these?
Alan
