IR diode looks photovoltaic outdoor
Discussion in 'Electronic Design' started by blisca, Feb 15, 2007.
  1. blisca
    blisca Guest
    hi,
    i'm doing a little experience with infrared emission,reception modulation
    etc
    eventough my system(very primitive) works fine indoor it is not the same
    outdoor,it looks that the sfh250 Ir receiving diode when exposed to the weak
    winter sun of northern Italy is able to generate about
    -400 mV on a 1MOhm load
    What is it due to? and how can i avoid it if possible?Shielding?Red glass
    filtering or what ??Thank you
    Diego
    Italy
  2. Paul Mathews
    Paul Mathews Guest
    Photodiodes produce current. Resistors create voltage drop
    proportional to current. The usual remedies:
    1) reduce load resistance, which also reduces sensitivity, of course
    2) apply reverse bias voltage, which may require capacitive coupling
    if the amplifier circuit is sensitive to DC level
    3) use a transconductance amplifier, which can be configured to keep
    voltage across the photodiode near zero volts
    Paul Mathews
  3. blisca
    blisca Guest
    thank you,very much,at first
    in the past days i used a TSOP1736,integrating filters ,demodulation and so
    on
    his feature should be high immunity to environmental light,but while exposed
    to the sun passing fast the hand and shadowing it quickly seems enough to
    turn it's output active
    strange,not?
  4. Paul Mathews
    Paul Mathews Guest
    Integrated IR photodetectors such as TSOP1736 usually include an
    optical filter that reduces effects of ambient light. However, they
    are not really designed to operate in daylight, since most people
    don't watch TV in daylight. Typically, their field of view is reduced
    by some type of aperture or tube placed in front of the photodetector.
    IR remote controls emit intense beams, and the 'commands' are
    repeated, with the user re-aiming the remote, until the desired
    results are achieved. You can use and aperture, tube, or lens to
    narrow the field of view.
    Paul Mathews
  5. Al
    Al Guest
    Use two photodiodes. Aim one at your source, the other someplace else
    neutral. Use a differential input and subtract one from the other.
    Al
  6. redbelly
    redbelly Guest
    What will also work, and be simpler, is to wire the two photodiodes
    together, in parallel but with opposite polarity. (cathode of one to
    the anode of the other, and vice versa).
    That way, the two should act as a single differential current source,
    requiring just a single amplifier or current-to-voltage converter.
    My coworkers and I used such a configuration years ago for a laser
    spectroscopy measurement.
    Mark
  7. blisca
    blisca Guest
    the fact is that the receiving circuit is mounted on a vehicle in a race
    track
    so i think that is difficult to separate useful signals from the "light
    floor"
    i'm not shure it will work in my case but it looks interesting
    Every time lot of things hint and ideas from the NG,thank you sincerely
  8. redbelly
    redbelly Guest
    Can you use a smaller load resistor? To avoid saturating the
    photodiode, the voltage should not be higher than about 250 mV or so.
    Mark
