IR Audio Reciever
Discussion in 'Audio' started by kpraytor, Oct 8, 2009.
  1. kpraytor
    kpraytor
    Oct 8, 2009
    Hello everyone!
    I am trying to make a simple go/ no go tester to determine if a remote control is outputting an IR signal. There is no need to clean up the signal or do anything else with it; I just need to know if the remote control is putting out any kind of IR.
    I have attached the first design I had. This appeared to function correctly but the signal was not strong enough to make a very audible note, aka you had to hold the speaker up to your ear to here the noise being produced.
    Unfortunately, I crossed some wires while testing it and fried the only speaker I had. Now, I am forced to go with a Piezo transducer to output an audio signal. It says on the packaging that it requires a driver circuit (?). I am new to the whole electronics thing and would like some advice concerning how to approach this driver circuit.
    Thanks for all your help and I look forward to the responses!
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Piezo buzzers are sometimes made with an internal driver circuit that only requires a dc voltage to make it buzz, while others contain only the piezo element and must be driven with ac to make a sound.
    A piezo element is a capacitor that bends when you apply a voltage to it. Try it out on your 9V battery; first touch it makes a click, then shorting the piezo it also clicks. Touch it to the battery again, and then reverse the polarity - it makes a louder click.
    An ordinary speaker conducts dc and needs a low voltage - high current signal to work, while the piezo requires a high voltage - low current signal and doesn't conduct dc.
    To get the high current for the ordinary speaker your circuit has two emitter-follower amplifier stages. You'll need to rewire it to make two common-emitter amplifiers to get the high voltage needed for the piezo speaker.
    But if you have a digital (cell phone/ web) camera you can use that to see the actual IR-light emitted by the remote instead.
Similar Threads
Loading...
