IR 9319 Transistor
Discussion in 'Electronic Repair' started by Phil, Jun 8, 2007.
  1. Phil
    Phil Guest
    I have a blown Transistor out of an electric wheelchair and cannot find a
    listing or cross reference for the International Rectifier No. 9319 , any
    help would be appreciated , this is a TO-220 case Trans.
    Phil L.
  2. Guest
    I don't think this is a transistor, as IR made vanishingly few of
    them. More likely a voltage regulator or SCR.
    If you change your search parameters, this might help.
    Peter Wieck
    Wyncote, PA
  3. Phil
    Phil Guest
    Thanks for the help , yes the 9319 is the mfg. date and P/N is PMC-NE8 and
    yes I can't find it for the homebuilder and no cross reference , Phil L.
  4. msg
    msg Guest
    Indeed it may be a thyristor; however I am currently using IR power
    mosfets in TO-220 cases. Your number may be a date code or house number too;
    please post _all_ identifying marks on the part for further research.
    Regards,
    Michael
  5. msg
    msg Guest
    <snip>
    That sure doesn't look like an IR part number; if the device was made
    by IR than that appears to be a customer's code. What brand is the controller?
    Most medical equipment service houses have cross references for all these
    parts (we have such a shop in our area that repairs wheelchair controllers
    and they certainly have manuals with component descriptions and cross-
    references).
    Regards,
    Michael
  6. Guest
    Might try here:
    http://www.icplus.net/frameresults.aspx
  7. Franc Zabkar
    Franc Zabkar Guest
    This site suggests that it is in fact a (MOS)FET:
    http://www.mark5.co.uk/proddetail.php?prod=PMC-NE8
    - Franc Zabkar
  8. From the Mouser website:
    IR Semiconductors
    • Diodes & Rectifiers (21)
    • MOSFETs & MOSFETs RF (105)
    • Thyristors - Diacs, Sidacs, SCRs & Triacs (7)
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  9. DaveM
    DaveM Guest
  10. DaveM
    DaveM Guest
    How old is the chair? That number looks suspiciously like a date code, and if
    so, it's absolutely useless as an identifying mark. It just states when the
    part was made.
    Any other characters/numbers on the part that might give us a clue? Have you
    tried contacting the manufacturer for replacement parts or identification of the
    part?
    As a last resort, contact an organization that services these chairs. They
    probably won't give you much advice, but it's worth a shot.
    One more last resort, you might have to bite a bullet and pay a service shop to
    repair it for you.
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    "In theory, there isn't any difference between theory and practice. In
    practice, there is." - Yogi Berra
  11. Why should "I" have to pay for the repair of the OPs power chair?
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
