IO mos
Discussion in 'Electronic Basics' started by jason, Sep 29, 2006.
  1. jason
    jason Guest
    Dear All
    Can you share with me what is the major difference between a logic mos
    and I/O mos?
    Does IO mos has longer gate length or thicker gate oxide or longer
    width...?
    Kindly share with me some idea.
    Thank you All
    best rgds
    Jason
  2. Rich Grise
    Rich Grise Guest
    This is a hard question to give a meaningful answer to, since those are
    different types of categories.
    A logic mosfet will reach saturation with a logic input, i.e., maybe
    5 volts.
    I/O just means "input/output", which is an application, rather than a
    type of fet, as far as I know.
    Consequently, a logic mosfet could be used in an I/O application,
    depending on the requirements.
    Hope This Helps!
    Rich
