inverter
Discussion in 'Electronic Basics' started by Bob19, May 23, 2006.
  1. Bob19
    Bob19 Guest
    Hi
    I want to build the inverter on the following page. It is a common inverter.
    Just like to know if the transformer need to be center tapped like the one
    shown.
    The transformer I want to use only has 4 wires, 2 input and 2 output
    obviously.
    So the question is, I should just ignore the center tap wire connected to
    the diode and power supply ??
    http://www.i4at.org/lib2/inverter.htm
    Robert
    just a starting out...
  2. Note that the +12 V DC connects to the center tap of the transformer.
    This tap is required in this circuit.
  3. John Larkin
    John Larkin Guest
    Also note that the capacitors are backwards.
    John
  4. ian field
    ian field Guest
    Which could get interesting if the specified tantalum caps are the military
    style hermetic metal cased types - the bead types just go off like match
    heads!
