Inverter That Produces a Sine Wave
Discussion in 'General Electronics Discussion' started by coolmike41, Mar 9, 2014.
  1. coolmike41
    coolmike41
    4
    Mar 9, 2014
    Hi I am building an inverter that is supposed to produce a sine wave(60Hz). It doesn't have to be an absolutely perfect sine wave (can have some small distortion).
    I am using an Arduino Uno to provide PWM to drive two signals that control MOSFETs in an H-Bridge.
    I keep seeing that people use a modified sine wave. The Arduino doesn't output negative voltages so what I did was take a sine wave and split it into its two halves- the positive and negative part. I am using two pins to output a PWM.
    --Pin #3 will output a PWM for the positive half of the sine wave and then stay OFF for the negative half.
    --Pin #11 will turn ON for the negative half of the sine wave and produce a PWM and turn OFF while the sine wave is in the positive half.
    So basically I have the two pins alternating ON/OFF depending on whether the sine wave is in the positive half or negative half.
    Is this methodology right? I am still getting a sine wave after filtering. I just haven't seen this kind of implementation anywhere (or maybe im not searching properly).
    Also what do you think the best type of filter would be for this H-brdige circuit? Im currently using a basic RC filter @ 60Hz
  2. (*steve*)
    25,496
    2,837
    This will work, but you could also use PWM to produce something like a sine wave varying between 0 and 5V, then pass it through a capacitor to eliminate the DC bias.
    The advantage of the H bridge is that you can concentrate on low pass filters only, and you will get twice the amplitude (and possibly twice the resolution)
  3. coolmike41
    coolmike41
    4
    Mar 9, 2014
    Hmm I see. My voltage source is 12v but my voltage output is only like 1V after the H-Bridge. I think that I am messing something up in my schematic regarding the MOSFETs
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    This sound interesting. When you say using PWM what does changing the pulse width do in your circuit? Do you have a circuit we can look at?
    Adam
  5. CDRIVE
    4,960
    652
    May 8, 2012
    Just to make sure you grasp what Steve posted I'm going to state it in other terms..
    If you couple a sine wave that does not cross zero (go negative) into a cap the output side of the cap will swing positive & negative. Stated another way... When capacitively coupling Pulsating DC .. true AC (+-) will be produced on the output side of the cap.
    Chris
  6. davenn
    davenn Moderator
    13,836
    1,950
    Im trying to picture that Chris
    I understand the Sine not crossing zero ... ie it has a DC offset
    not sure how the cap is connected into this arrangement ?
    can you diagram that for me please ?
  7. CDRIVE
    4,960
    652
    May 8, 2012
    Sure Dave. Like this.
    Chris
  8. davenn
    davenn Moderator
    13,836
    1,950
    well there ya go!!
    thanks Chris
    that's easier than I realised ... shows a few gaps in my theory knowledge huh LOL
    mite have to play with some square waves out of the sig gene and see how clean a sine wave I can got on the scope :)
  9. CDRIVE
    4,960
    652
    May 8, 2012
    Dave, you just had a "Senior Moment"! :D
    Regarding square waves....My guess will be a droopy square wave but it will swing above and below zero. ;)
    Chris
  10. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Hi Chris.
    Doesn't that depend on the time constant versus frequency? A larger resistor would lift the signal up towards 0V and a smaller resistor should bring it down. If you go even further down in resistor value then noticeable differentiation is going to happen isn't it? I am thinking about 10 times RC greater than pulse width to give you equal +/- with limited slew on the top of the pulse. What do you think?
    Adam
  11. davenn
    davenn Moderator
    13,836
    1,950
    haha yeah, they are becoming more regular these days ;)
    KRAFTS disease .... wonder if you have heard of that one ?
    Hint: its NOT a real diease
  12. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    LOL Dave, don't you mean CRAFT disease, Can't Remember a Freaking Thing. Look up KRAFTS disease on Urban dictionary. PSML.
    Adam
  13. CDRIVE
    4,960
    652
    May 8, 2012
    I'm not sure what you're implying about "towards 0" but sufficed to say that F, C & R all play a part in the faithful reproduction of the signal,.. along with + & - symmetry.
    There are other factors too, especially if the signal is a square wave or rectangular .... (not a 50/50) duty cycle. The Source/Sink impedance of the source must be equal or many orders lower than the load, as to be insignificant to the RC time constant. A single transistor (common emitter) switch mode amplifier with collector resistor will have a much higher source impedance than its sink impedance when biased to saturation. Positive/ Negative symmetry will only be achieved when RL is much higher than the collector resistor.
    All that said, I suspect I'm not telling you anything you don't already know. ;)
    Chris
  14. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Thanks Chris
    Adam
  15. coolmike41
    coolmike41
    4
    Mar 9, 2014
    Basically im using the PWM to trigger an H-Bridge on/off. I have a separate DC power supply that will feed into the H-Bridge and I basically am turning it into a sine wave.
    I have a prototype but I need some MOSFET drivers as the microcontroller doesn't have enough amps to turn on my MOSFET so im getting major power loss.
    For the filtering system i'm using a basic low pass RC filter tuned to 60Hz. I'm not sure if I should look into better options though
    See attached image even though its kinda crude
      File size:
      31.5 KB
      131
  16. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Your power loss is probably due to the fact that the two bottom BJTs need a base resistor to limit the current. What you have done is the same as connecting a forward biased diode across the outputs of the PIC.
    Also if you have two more PWM ports then it is more efficient to use PNP versions for the top two transistors.
    Adam
  17. coolmike41
    coolmike41
    4
    Mar 9, 2014
    I am using mosfets not bjts.My image just shows bjt's since i copied a basic schematic off google images
  18. CDRIVE
    4,960
    652
    May 8, 2012
    That's not an acceptable alternative to posting a schematic. It's akin to saying "That's not a capacitor in the circuit. I didn't have any resistor models so I used a cap instead". MOSFETs and BJT's have little in common.
    Chris
  19. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Yes I agree Chris, that's what confused me.
    Adam
  20. CDRIVE
    4,960
    652
    May 8, 2012
    Well I may be all wet here or I'm missing something,.. but since a Sine Wave inverter is required or desired why not use the DAC output?
    Chris
