John Dunkley
I would be grateful for some advice on an inverter problem on my PV system.
Background info:
Brand new 300 watt continuous true sine wave inverter that has a 1000 watt
output surge capacity.
12 volts DC to 240 volts AC
With my PC and LCD monitor connected to the inverter, the inverter shuts
down some 15 seconds after the PC boot-up.
I have data logging equipment and logging the current drawn by the PC/LCD
the maximum current drawn is 0.7 amps which equates to approximately 170
watts. There is of course a lot of PC hard disk 'activity' during these
first 15 seconds.
If I remove the LCD monitor, the PC boots up OK and after waiting 2-3
minutes until the PC boot up activity finishes, and then connect the LCD
monitor to the inverter, the system runs OK with no shut down of the
inverter. The LCD monitor by itself draws a fairly constant 30 watts. Power
drawn is then a fairly stable 80 watts with the occasional jump to 170 watts
with hard disk activity.
The only thing I can think of is that there are some higher 'surges'
produced by the PC during those first 15 seconds that my data logger is not
capturing that is shutting the inverter down - but 170 watts is still a
long way from the inverters 1000 watt surge capacity.
Assistance/advice regarding this problem would be appreciated.
I might add that I am a newbie to this particular news group and it is very
nice to see the manners and assistance provided by its participants. This is
very refreshing compared to some other news groups I monitor!
Must be all gentlemen here!
JD
Australia.
Background info:
first 15 seconds.
JD
Australia.
