B
Brian Graham
I have a question about inverters and circuit planning.
The Xantrex 1850 is a 15A inverter. IE, good enough for 1 full 15A circuit. But clearly you don't load it with only 1 circuit, especially lighting.
So lets say it runs my upstairs lighting, furnace fan and either the microwave OR washer OR dishwasher. But if someone inadvertantly runs the washer & dishwasher at the same time its going to blow the fuse to the inverter.
So would you actually get as many inverters as necessary so there was a max 15A draw on it at any point in time? But it wouldn't make sense to have an inverter dedicated to the washer alone, most of the time sitting there doing nothing. And then how do you plan circuits with receptacles, where all of a sudden a large temporary load is added - such as a vacuum - which now overloads the circuit? I can't imagine you'd buy an extra inverter to handle a circuit of receptacles which are normally unused.
What I'm trying to get at is how much is load balancing, knowing enough not to run certain items together, and how much is done in balancing inverters loads? (So hard to write this clearly and succinctly..)
The answer can't be to just get a larger inverter. The same concept can occur with a larger one too..
