N
Nick Hull
I'm using a cheap 300 watt inverter with 2 golf cart batteries to power
emergency lights during power failures. I found that 12 vdc
flourescents were expensive and had short lives, so I'm using 110vac CFs
powered by the 300 watt inverter. Works very well EXCEPT for an
occasional glitch, where the inverter turns off due to a transient hab
has to be manually reset.
I'm not sure where the transient comes from, I can not duplicate it in
tests. The inverter is connected to the batterys and a float charger
keeps them topped. Plugging & unplugging the float charger does
nothing. The Inverter output goes around the house to various CF bulbs
on manual switches and one automatic switch, maybe 50' total wiring some
of which parallels existing house power wiring but no motors or heavy
loads.
Not much info, wut what could be causing the glitch that turns my
inverter off and how might I fix it or troubleshoot the problem?
loads.
