Jim Wilkins said:
This is the manual for the Yamaha EF1000:
http://www.yamaha-motor.com/assets/service/manuals/0/LIT-19626-01-19_1109.pdf
The schematic at the end shows two three-phase permanent magnet
alternators (1,2) which presumably are rectified to DC and then
inverted to 60Hz AC. I haven't worked on one of these generators but
motorcycles use those alternators.
I would guess that one of the alternators must put out enough voltage
at idle, the other is more efficient at high speed. The stepping motor
(21) might control the throttle. The bottom part of the schematic is
the engine ignition.
jsw
Hey Guys, Just a NOTE here: ALL Electrical Generators produce their
power in AC, PERIOD. What you think of as DC Generators have Commutators
that convert the AC from the windings, mechanically to DC, coming off
the Commutator Brushes. In the Inverter/Generator case, the Main Genend
Windings, are 3 Phase AC that is rectified, to DC and then feed into the
DC input of the Main 60 Hz Inverter. If the load Power is more than the
DC Input to the Inverter Section then the CPU Controller ramps up the
Throttle on the Engine to provide the required Power for the load. this
way the engine only provides just enough power to satisfy the load on
the output of the inverter, thus saving fuel, and machinery wear. Great
concept but give me a nice old Diesel 1800 RPM Genset any day.
