Interupting xenon flash current ?
Discussion in 'Electronic Design' started by Mike, Dec 5, 2007.
  1. Mike
    Mike Guest
    I was reading about how autoexposure and speed flash units work and found out that in modern units IGBTs are
    used to turn off the tube current at the proper time. I scrounged up the parts to flash a tube and measured
    the current pulse during discharge. For my test setup I measured the the current peak to be about 1900A and am
    fairly certain that number is pretty close. The current was above 1000A for about 6us and still at 300A after
    200us then finally decayed to 0 after about 600us. How is it possible for any reasonably priced/sized IGBT to
    survive under that kind of stress? I was going to try interupting the pulse, but the only IGBT I have is one I
    took from a dead microwave oven inverter and it's only rated at 150A for 1ms. My test setup isn't all that
    powerful, only about 37J (600uf flash cap charged to 350v). I'm also curious about why it takes 20us from the
    time of the HV trigger to the time the tube starts to conduct. It may not be, but that just seems like and
    awfully long time. Not enough trigger voltage maybe? Also, it takes another 15us for the current to reach
    it's peak. Unfortunately I don't have any data for the flash tube. It is fairly large, 80mm long and 8mm dia.
    The trigger is a thin wire spirally wrapped the entire length of the tube.
    Mike
    If there is no absolute truth then nothing can be known.
  2. I always tought a SCR, not an IGBT, was fired parallel to the flash tube.
    And the flash tube is connected via a small inductor to the cap,
    the inductor limiting the current rise.
    But it has been at least 20 years ago I looked....
    Anyways SCRs can have huge peak currents.
  3. Jim Thompson
    Jim Thompson Guest
    I did that in the '60's, but used an SCR, read my patent at...
    http://analog-innovations.com/SED/Pat-3496411.pdf
    ...Jim Thompson
  4. I believe there is a mistake with your measurement. In the common
    cameras, the flash current is at the order of 100A and the duration is
    ~tens of milliseconds. They handle it with IGBT of SOT-223 form factor.
    However there are the special pulse tubes for use with lasers, etc. They
    have higher rate of the current increase and the shorter flash duration.
    Vladimir Vassilevsky
    DSP and Mixed Signal Design Consultant
    http://www.abvolt.com
  5. John Larkin
    John Larkin Guest
    The IGBT itself will limit the current. And waste some energy, I
    assume.
    John
  6. Mike
    Mike Guest
    That was my frst reaction also since I expected to see something less than 400A, but I can't find any reason
    for such a major error.
    I have a 200mv 200A shunt in series with the tube and am simply grabbing the voltage waveform across the shunt
    with an HP 54502A storage scope. So with 1mv/A and reading 1.9v peak that's 1900A. I connected the 1V scope
    calibrator output from an analog scope to 54502s input and it reads right on amplitude and time.
    Mike
  7. Mike
    Mike Guest
    Yep, but the reason for opening the circuit instead of shunting the tube is to leave the unused charge in the
    cap to allow much quicker recharge time.
  8. Mike
    Mike Guest
    and I fear, fusing to a blob of silicon in the process. :)
    Mike
  9. This isn't a case of "current limit". It actually does indeed interrupt the
    flash tube current abruptly.
    That's the only way that modern flash can work predictably, controllably and
    repeatably.
    I looked into this (for a non-commercial application) some time back and
    couldn't find any off the shelf (one piece) semis that could do it. I
    couldn't find any specific data on the way it was done, so suspected they used
    two devices, an SCR as per normal, and a more traditional semi switch to turn
    it off after the predetermined delay.
  10. Mark
    Mark Guest
    two possible sources of error
    1) if the shunt is inductive it will read higher for the pulse
    2) you may have a hugh common mode problem, i assume you have the
    shunt in the low voltage returm path...anyway, try connecting both
    ends of the scope probe to the same side of the shunt, i.e. you should
    expect to see 0V pulse when you fire the strobe...and check if you
    do...
    you may need to use a differential probe or other special technique to
    get an accuragte small signal measurment in the presense of the large
    discharge pulse..
    or use a larger value shunt...
    Mark
  11. I bet it is either inductive or capacitive parasitic pickup or a common
    ground problem.
  12. Well, if that's what the 'scope shows, it's *got* to be true.
    Best regards,
    Spehro Pefhany
  13. John Larkin
    John Larkin Guest
    A couple of people make ICs that do the whole function: flyback
    converter, trigger stuff, IGBT gate driver with timing.
    Shunt igbt, wastes energy:
    http://focus.ti.com/lit/an/slva197/slva197.pdf
    Series:
    http://www.onsemi.com/pub/Collateral/NCP5080-D.PDF
    There are several others.
    John
  14. John Larkin
    John Larkin Guest
    Current shunt inductance can be a serious error in this time domain. A
    current transformer would probably be more accurate, and avoid ground
    loops too.
    1-turn primary, maybe 100 turn secondary on a ferrite toroid, 1 ohm or
    less non-inductive burden resistor. We've done this in the 100 amp, 50
    ns sort of range, on a node that kicks a kilovolt, and it worked well.
    John
  15. Yes, but where were they when I needed them back then? :)
  16. John Larkin
    John Larkin Guest
    Maybe they didn't exist?
    The older controlled-flash units had two flashtubes, one to actually
    flash, and a second shunt tube, inside, that shorted out the cap when
    enough light had been generated.
    John
  17. Mike
    Mike Guest
    Thanks, I had no idea anyone made a controller like that.
    In looking at the data sheet and their demo board info, I see they are dealing with an 80A pulse with only 1J
    and small tube. So maybe my measurment isn't all that far off.
    Mike
  18. Winfield
    Winfield Guest
    They show a flash-tube current of 60A peak (with
    a short little extra bit to 80A) decaying with an
    approximately 70us time constant. They suggest a
    CY25BAH-8F IGBT, which is a 400V "150A" Renesas
    part in a tiny tssop-8 package.
  19. Mike
    Mike Guest
    I wonder how I might calibrate such a homebrew current transformer?
    Shouldn't I see some serious ringing in the current waveform if my shunt is that inductive?
  20. Mike
    Mike Guest
    This is a very low inductance shunt. It consists of 2 straps of resistance material about 1" wide and 5" long
    stacked on one above the other in brass blocks with Kelvin sense terminals. I just measured the inductance to
    be 0.2 to 0.4uH. It wants to drift around a bit. I have used this same shunt to measure a 3000A pulse in an
    impulse magnitizer that I built, but that was a much longer pulse. Somewhere around 8ms if I remember
    correctly.
    Yes the shunt is located between the capacitor neg terminal and the flash tube. The scope gnd, the charge
    power neg, capacitor neg, and shunt are all connected to the same node. I connected the scope probe tip to the
    that same node and the scope showed zero voltage.
    Mike
