hello friends,
i am calculating internal resistance of a car battery during the charging phase. When the car is moving the alternator keeps on charging the battery if the output voltage of the alternator is greater than the battery voltage. Basically to proceed with this i have input of continuous voltage and current which is measured at the battery terminals. These signals are in phase and that means its a pure resistive circuit. So the voltage divide by the current has to give the internal resistance value. If we consider an open circuit in which the internal resistance would be calculated as,
Ri=Voc-Vterminal/Ibatt
but when i have to calculate the battery internal resistance during its charging phase then how i amply this formula because in this case i have voltage and current signal which are measured at its terminal and its going to be a closed circuit. So should i directly divide Vbatt/Ibatt to get internal resistance or something else?
The other thing is the voltage and current has ac component that is some ripples so how to consider these ripples to get internal resistance?
thanks
thanks
