Interleaved active clamp flyback converter
Discussion in 'Power Electronics' started by Dipak_rathod, Nov 18, 2019.
  1. Dipak_rathod
    Dipak_rathod
    Nov 18, 2019
    as per the figure we provides a dc voltage as a input to the interleaved active clamp flyback converter block, provide a PWM signal to the MOSFET which is in interleaved block for switching purpose. PWM signal is generated by the microcontroller which has a fix frequency 57 KHz and 50 % duty cycle then we got a output like triangular waveform. actually we will need a output like a given figure so which type of PWM output will be provided to the switching MOSFET, so we got proper output of the interleaved active clamp flyback converter.[​IMG]
  2. Harald Kapp
    10,025
    2,138
    @Dipak_rathod : Your image doesn't show. Use the image upload (menu bar, right of smiley) or pastethe image directly into the editor window. Note a size limit of approx. 100 kB.
  3. Dipak_rathod
    Dipak_rathod
    Nov 18, 2019
    As per the figure we provides a dc voltage as a input to the interleaved active clamp flyback converter block, provide a PWM signal to the MOSFET which is in interleaved block for switching purpose. PWM signal is generated by the microcontroller which has a fix frequency 57 KHz and 50 % duty cycle then we got a output like triangular waveform. actually we will need a output like a given figure so which type of PWM output will be provided to the switching MOSFET, so we got proper output of the interleaved active clamp flyback converter.
      File size:
      31 KB
      8
