A
Antonis Konstantinos
Hi All,
I am now building a system which will be communicating to another
system via UART at low rates (4800 bps)
The board that I am building will be powered up from an SMPS and the
other system has its own power supply. I plan to connect the uart
lines directly (without any buffer, optocoupler etc.) to my micro and
connect the ground of each system together.
Both systems uses 5V logic.
I have already built the system and it works fine *for now*.
Do you think that there is a more appropriate way of doing this? If so
what would you recommend ?
Thanks in advance,
Regards
Thanks in advance,
Regards
