interface arduino with telit gm862
Discussion in 'Microcontrollers, Programming and IoT' started by okili, Jun 3, 2012.
  1. okili
    okili
    Jun 3, 2012
    good morning
    i am facing problem interfacing my arduino with the gm862. Actually i am able to make a call to the gm862 module . but unable to make the microcontroller which is the atmega328 send a sms through rx and tx. this is the sample code that i have used is compiling without errors.
    #include <SoftwareSerial.h>
    int rxPin = 0;
    int txPin = 1;
    // set up a new serial port
    SoftwareSerial serial=SoftwareSerial(rxPin,txPin);
    void setup() {
    pinMode(rxPin, INPUT);
    pinMode(txPin, OUTPUT);
    // set the data rate for the SoftwareSerial port
    serial.begin(9600);
    // Set SMS to text mode. Note it is critical
    // to use \r\n to end each line
    // The delays are also critical, without them,
    // you may lose some of the
    // characters of your message
    serial.print("AT+CMGF=1\r\n");
    delay(300);
    serial.print("AT+CMGS=");
    delay(300);
    // Replace with a valid phone number
    serial.print("00233240582093\r\n");
    delay(300);
    serial.print("Hello from Arduino.");
    delay(300);
    // End the SMS with a control-z
    serial.write(0x1A);
    void loop() {
