Interface a bike computer
Discussion in 'Misc Electronics' started by [email protected], Mar 7, 2007.
  1. Guest
    Hi All - I need some help/advice.
    I'd like to connect a magnetic sensor (bicycle computer) directly to
    my computer through one of the ports without a power supply.
    I found a circuit that connects the magnetic sensor directly to the
    parallel port but don't know how to test it. The magnetic reed switch
    I'm using should produce a passive current when my wheels are turning
    but is this enough to be detected through my parallel port?
    Can anyone make suggestions about circuit design - can I feed the
    wires directly into my parallel/serial port?
    I'm also trying to write a program in VB6 to read the input, but not
    having much luck.
    I'd really appreciate any help anyone could give me.
    Pete
  2. quietguy
    quietguy Guest
    You might have a look at the Windmill software - it might be useful
    David
