P
Phil Allison
"Bob Parker
** Well, it sure as hell clarifies it ain't a line scanner - it's a camera.
........ Phil
Phil Allison
Google might be my friend, but searching for technical info on the
actual Dolby 701/702 digital track readers and their CCD sensors ain't
easy! I found heaps of info about how to install them into various models
of projectors and connect and align them, though.
Anyhow, http://www.hps4000.com/pages/digital/dolby_sr_d_digital.pdf
says...
The data block is read by a 512 element charged coupled device (CCD),
which is, in essence, a television camera. The output of the CCD is an
analog video "picture" of the spots on the film. This is converted into
the digital video domain at a rate which tracks the speed of the film.
This video data is scanned for synchronization information and to
determine where the four corners of the data block are located. If two of
the corners are known, the position of the entire block is known and the
proper location of the data bits is known. Determining the whether or not
a real data spot exists and preventing false data from entering the
process is best understood by imagining a piece of window screen being
placed directly over the data block. The corner bits verify the proper
Position for the screen. Looking at the "screen", one sees in the small
square openings exactly where the spots should be. Using a digital version
of such a screen, the data spots are identified and then sent to a
"thresholding" stage for further enhancement. Based on the average density
of the spots, a threshold value is determined, above which the spot is
recognized as a "1" and below which, a "0". This stage reduces the
possibility that a scratch could be mistaken for actual data and
establishes what, on the film, is a spot and what is not.
I'm not sure if that clarifies anything or not.
........ Phil
