S
Skybuck Flying
Hello,
I was just playing Dark Messiah of Might and Magic and I noticed my cooling
fans and making quite some noise !
Like BZZZZZZZZZZZZZ... they are spinning at full speed.
And when I rebuilded my PC I noticed lot's of heat inside the case coming
from the chips and such.
As soon as I removed the case, the heat came free and the fans started to
spin more slowly so that's a clear sign the heat is not getting
properly transported out of the system.
The two harddisk fans might not even be required...
Maybe on harddisk fan enough.
Maybe I should replace one harddisk fan to the cpu section... near graphics
maybe... or just maybe near cpu where it's most hot...
However I am not sure if the fan should blow inwards or outwards...
Anyway interesting discovery...
Maybe I should go look for a better case with more airflow... or maybe first
try to fan replacing..
I'll try that first if possible
Also without the case door the case starts humming maybe if I remove other
case door it will be more in balance.
Yeah not sure what to do with airflow... in or out hmm...
First gotta detach one harddisk fan since I need those screws
Unless I can find screws some where else..
I specially ordered those screws... hmm I must have a few spare somewhere I
think not sure though.
Later
Skybuck,
Later
Skybuck,
