S
Sam Goldwasser
Jim Yanik said:I've wondered if low melting point solder like what comes in the ChipQuik
desoldering kit might work on thick-film connections.It wasn't available to
me at Tek.The conductive silver epoxy may be a better idea. Trouble if you
have to resolder the thick-film back into the motherboard.
I don't know but I have both indium solder (93C) and that ChipQuik stuff.
However, if I can identify one cracked joint, the silver Epoxy should take
care of it.
I have no intention of removing the hybrid from the mainboard! Silver
Epoxy on those joints as well if need be.
Alternately,you could fashion a small PCB to fit where the thick film
goes,and solder your resistors to the PCB. I've not tried this,though.
So far the cleaning is holding up. Fingers crossed.
Thanks.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
