JURB6006
Hi folks;
Hope yall had a nice Eve and wish you the best holiday.
If Santa is welcome at your house I hope he needs a Tractor-trailer to bring
you good stuff (pretend to be sleeping then)
Now that things have settled down . . . .
One of the things I did today was to go hook up a new PC system, integrated
with the A/V stuff. Cable signal also goes to the PC and we ran back SVHS and
L/R to the TV (Mits. 35MX1). I thought the TVO portion of the ATI All in wonder
wasn't working. Switching to a regular input worked, I used the right audio
cable for the composite video.
Now there is another issue. We could just run composite but this is no good,
the signal is slightly off standard (it is) and the Mitses COMB filter doesn't
work well with it.
Some frequency is set different, when a saturated color comes on, the dots are
stationary. You see them on alot of NTSC sets, and with one line COMB filters
the first line of a saturated block displays a serration, or if the COMB isn't
working correctly a hatch pattern throughout the colored block or object.
However, on a "legal" NTSC signal this pattern appears to move. This is of
course because the designers of the system chose the frequencies used so they
would cause cause "interlace". On the ATI card output, the "hanging dots" are
stationary on a stationary image. The chroma frequency must be shifted
slightly, and I believe intentionally, to simplify encoding (ATI Radeon 7500
All in Wonder w/ 64MB, remote), thus making the SVHS cable necessary.
We lack the original remote to the set and can't seem to get it into the SVHS
mode. Being a tech. I think I can force it into the SVHS mode no matter what
system control says, but that is some work, especially in this installation.
Note that as a tech I absolutely refuse to try to align the COMB filter to this
source. This would degrade all normal inputs.
Also, I wonder, will a VCR record that non-standard signal ? Probably I think,
but I wonder just how much it's degraded. Luminance will be filtering out a
3.5???? Mhz signal, which might not bother it too much. The chroma noise
reduction scheme will probably be quite compromised though, it might even
record in black and white.
Recording VHS from this source is not the important point, image quality is,
this is way worse than it should be, and the COMB filter is working, but when
the frequency is off. . . . . I guess we need to get it switched to the SVHS
input.
Advice, comment, suggestion ?
Thanx for anything on this and thanx for even reading this.
Merry, happy, joyful
Christmas, Chanukah, Kwaanza (sorry if I spelled it wrong), Ceremony of the
Rebirth, whatever you have,I wish you a good one.
JURB
work well with it.
input.
JURB
