integrated amplifier
Discussion in 'Audio' started by alanong, Jan 22, 2019.
  1. alanong
    alanong
    Jan 22, 2019
    I accidentally dropped my Cambridge amplifier CXA80 from a height of 3 feet while transporting it in a box.
    So far it is performing. How do I test if there is any resultant damage ?
  2. Harald Kapp
    9,651
    2,017
    Check all functions. If all is well, no problems should occur.
  3. dave9
    dave9
    863
    211
    Mar 5, 2017
    By running it till it gets hot(ish) to see if the temperature rise causes any cracked solder joint, brittle component like something surface mount, or PCB trace to break the circuit.
