Instrument with analog output, cheap and on RS232/USB
Discussion in 'Electronic Design' started by Klaus Kragelund, Nov 3, 2012.
  1. Hi
    For a test setup I often need an analog signal to feed into the device under test.
    So I need a instrument with an anlog output. It needs to run on RS232 or USB
    I could roll my own, with a eval board, but have no time to spend on that
    Anyone know of a cheap model (no the National Instruments, NIDaqs, they are prohibitive expensive)
    Klaus
  2. Rich Webb
    Rich Webb Guest
    Bandwidth? Memory depth? Resolution? Sync trigger?
    This http://www.circuitspecialists.com/dds-3005usb.html might do the job
    and it's fairly inexpensive.
  3. Have you looked at Measurement Computing? They are inexpensive, less
    than NI.
    <http://www.mccdaq.com/solutions/USB-Data-Acquisition.aspx>
    Cheers
  4. rickman
    rickman Guest
    I assume a standard USB stereo audio adapter for the PC won't work?
    Rick
  5. Nico Coesel
    Nico Coesel Guest
    You can use a cheap PLC like this:
    http://www.xlogic-plc.com/
    or a programmable power supply like this:
    http://www.ebay.com/itm/261050328132
  6. I bought this 30V/5A one for USD $99 (£61) including shipping with
    (isolated) USB and RS-232 interfaces. Seems to be unavailable from
    that source atm. I think it's okay Chinese quality, but probably rated
    a bit "optimistically" according to DJ's vblog. No NA safety
    approvals. It's a kind of spare for when the 3-output Rigol is being
    used or maybe for risky types of loads.
    http://www.amazon.com/gp/product/B0085QLNFM/ref=oh_details_o03_s00_i00
    Speaking of Rigol, if you want more like a signal, these units are a
    bargain, in a different class quality and design-wise. They have an
    Ethernet interface (inherently isolated), and two signal generators,
    so you can generate a 50MHz sine wave frequency modulated with a 1MHz
    triangle wave if that's what you want.
    http://www.rigolna.com/products/waveform-generators/dg4062/
    They have higher frequency units, but the price goes up quickly for
    the additional capability.
    Best regards,
    Spehro Pefhany
  7. That's not bad. I was talking to a physics prof. (UC Davis?) who
    had an experiment where he put together different lengths of 50 and 75
    ohm
    cable, making variable wavelength 'sturctures'.
    And drove it with a ~50MHz. generator.
    George H.
  8. Joerg
    Joerg Guest
    This is the one I use for that purpose:
    http://labjack.com/u3
    That way you have it in a sturdy plastic housing. Comes with the lite
    version of DAQFActory which is quite useful. I really like it. Well,
    except for that blood-red color.
    This device is also handy for niftier test setups. For example "I want
    this line to switch to 3V tomorrow at 10:16am but only if there is
    enough daylight, and then gradually ramp down to 0V until evening".
  9. Thats a nice device and in the right pricerange, thanks :)
    Regards
    Klaus
