A
amdx
I found this IRF510 mosfet spice model on the IR site. ((see bottom of
page))
There seems to be 5 different models.
I want to install an IRF510 model in
C:\programfiles\LTC\SwCADIII\lib\cmp\standard.mos.
While looking in this file, I see the model below.----
..model IRF1302 VDMOS(Rg=3 Vto=4 Rd=1.6m
Rs=1.2m Rb=2m Kp=50 Cgdmax=5n Cgdmin=1n Cgs=2n Cjo=1n Is=160p
mfg=International_Rectifier Vds=20 Ron=4m Qg=80n)
This model doesn't have the same info as the one I downloaded from the IR
site, which
seems to have 5 different models.
Is there a better model, (more similar to the one above) OR which of the
models below
should I pick MM, MD, MD1, MD2 or MD3?
Again, my goal,
Thanks, Mike
..SUBCKT irf510 1 2 3
* Model Generated by MODPEX *
*Copyright(c) Symmetry Design Systems*
* All Rights Reserved *
* UNPUBLISHED LICENSED SOFTWARE *
* Contains Proprietary Information *
* Which is The Property of *
* SYMMETRY OR ITS LICENSORS *
*Commercial Use or Resale Restricted *
* by Symmetry License Agreement *
* Model generated on Apr 24, 96
* Model format: SPICE3
* Symmetry POWER MOS Model (Version 1.0)
* External Node Designations
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
M1 9 7 8 8 MM L=100u W=100u
* Default values used in MM:
* The voltage-dependent capacitances are
* not included. Other default values are:
* RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
..MODEL MM NMOS LEVEL=1 IS=1e-32
+VTO=3.82703 LAMBDA=0 KP=2.48457
+CGSO=1.72132e-06 CGDO=5.99235e-11
RS 8 3 0.276929
D1 3 1 MD
..MODEL MD D IS=6.52734e-11 RS=0.0458243 N=1.2565 BV=100
+IBV=0.00025 EG=1.2 XTI=1 TT=0
+CJO=2.98645e-10 VJ=0.774158 M=0.422859 FC=0.5
RDS 3 1 4e+06
RD 9 1 0.0673242
RG 2 7 13.1694
D2 4 5 MD1
* Default values used in MD1:
* RS=0 EG=1.11 XTI=3.0 TT=0
* BV=infinite IBV=1mA
..MODEL MD1 D IS=1e-32 N=50
+CJO=1.85121e-10 VJ=0.500044 M=0.651006 FC=1e-08
D3 0 5 MD2
* Default values used in MD2:
* EG=1.11 XTI=3.0 TT=0 CJO=0
..MODEL MD2 D IS=1e-10 N=0.4 RS=3e-06
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
CAP 11 10 3.40332e-10
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
* Default values used in MD3:
* RS=0 BV=infinite IBV=1mA
..MODEL MD3 D IS=1e-10 N=0.4
..ENDS
page))
site, which
models below
Again, my goal,
Thanks, Mike
* Node 1 -> Drain
* Node 2 -> Gate
* Node 3 -> Source
RS 8 3 0.276929
D1 3 1 MD
RDS 3 1 4e+06
RD 9 1 0.0673242
RG 2 7 13.1694
D2 4 5 MD1
D3 0 5 MD2
RL 5 10 1
FI2 7 9 VFI2 -1
VFI2 4 0 0
EV16 10 0 9 7 1
FI1 7 9 VFI1 -1
VFI1 11 6 0
RCAP 6 10 1
D4 0 6 MD3
..ENDS
