installing a remote switch
Discussion in 'Electronic Design' started by jim, Mar 13, 2005.
  1. jim
    jim Guest
    I have cooling unit with an on/off switch inside the casing. I want to install
    a remotely controlled on/off switch. I have already purchased the remote switch and
    have tested it on a household light and it works fine at a distance of 25 yards. In fact,
    it is an RF type switch that works through walls, etc. The switch (relay) module has
    mains input/output wires 240 V A/C and a maximum load of 1000watts.
    Here's the wiring diagram of the cooling unit:
    http://homepage.ntlworld.com/davidsallows2004/March-13,-2005.gif
    I would like to switch the compressor on and off with the remote switch or if that's not
    possible, then switch the whole thing on/off.
    The question is where do I put it?
  2. Fred Bloggs
    Fred Bloggs Guest
    That particular unit operates by using the refrigerant pressure in the
    suction line as a thermostat- closing on pressure rise corresponding to
    to cut-in temperature. That particular switch is connected at the bottom
    just to the left of the compressor with PK/BR wires labeled "in-line
    connectors"- closing those switch contacts, shorts PK/BR and connects
    "LINE" to RD on the upper terminal block- RD routes to middle "modular
    terminal block" and wire color BR to common RUN/START winding connection
    of compressor- then from RUN to BLK and START to WH to CAP to BLK which
    is connected to Neutral at upper terminal block. The same pressure
    switch also throws power to the FAN and its components. That circuit
    also passes the full unit load power and is most likely beyond the
    rating of a 1000W remote switch- you may need to use the switch to
    control a contactor which closes the main circuit. Also- it is not clear
    what you want to do with this control. If you want to enable the unit to
    start its normal cooling operation, off otherwise, then put your switch
    *in series* with the BR wire at the pressure switch; if you want to
    override the temperature regulation, then use your switch to short
    switch PK/BR together. At least this is what it looks like to me.
  3. Fred Bloggs
    Fred Bloggs Guest
    This statement "The switch (relay) module has mains input/output wires
    240 V A/C and a maximum load of 1000watts" says nearly nothing specific.
    If your switch module throws live power, or if there is any doubt about
    what it does exactly, then wire a contactor into the pressure switch
    circuit, and use your module to throw power on the contactor coil.
