insolation tables, interpretation
R
Robert Morein
Are the table values the watt-hours per square meter of earth surface, as
opposed to a panel with a more optimal orientation?
D
daestrom
Which table are you looking at? Most will have some preface that explains
your question.
http://rredc.nrel.gov/solar/old_data/nsrdb/redbook/atlas/
Allows you to pick from several possible collector orientations/designs.
Including a horizontal plate, vertical plate, mounted at latitude etc...
daestrom
N
no useful info
your question.
daestrom
I'm just trying to imagine any kind of reputable table that wouldn't
clearly explain what the data represented.
Of course one would have thought that a PhD candidate in Engineering
would be capable of deciphering such info.
N
no useful info
Robert Morein said:
Thank you. Apparently there is no single standard interpretation.
Some tables imply that the values apply to an optimally oriented surface,
ie., a panel mounted on a tracker.
damn, there you go again asking another question you already knew the
answer to.
