Frank Miles said:
Fred Bartoli
[snip]
Well, I've finally got doing that low noise preamp: the target is
200pV/rtHz, bandwidth from 0.1Hz (with provision for 1/f noise) to
1MHz.
[snip]
85mA 85mA
to to
125mA 125mA
V V
| .-.R3 | .-.R4 | /| | | |\ |
| | | 2 V |
clamp --. | .-------------------' |
| | | | | | ___
| | | | | .---------------------|___|-.
10u | J1 |-+ | +-|J2 | | | R2 |
|| | | | | | | ___ | |\ |
in -+--||--+--->|-+ | +-|<-------+-|___|-. | .----|+\ |
| || | | | | |5mA R1 | 5mA| | | >-+-out
.-. .-. '---+---' | | GND | | GND .-|-/ |
| | | | | | V V | | |/ |
1M'-' '-'1G | | Precision |--+--||--+
| | V | current mirror | .-.
GND | 160mA '-----------------------' | |
| to /| | |
| 240mA /+|-GND'-'
[snip]
Yup. From the whole bunch of pb I could list I'm pretty safe to say that
this is probably the limit of what's doable at room temperature.
I don't know if you can meet the noise specs by going down this pathway,
but if the series RC shunting the input adds too much noise, I think you're
going to have to bootstrap your input circuit to get rid of the negative RC
Zin. This will have to operate at high speed -- not at the slow speed of
the feedback loop. Of course there are limits to this approach as well, but
with the right topology you may be able to use a pure capacitance between J1's
gate and an appropriate virtual ground input node to provide a high frequency
boost to J1's source. This has been done, for example, in a few oscilloscope
vertical inputs to provide a wider-band input while reducing the dribble-up
behavior of real follower circuits which have capacitive loading.
Hmmm, now that sounds interesting. That really is a clever trick, if I
understood correctly what you meant.
Do you have any specific scope reference or schematics to look at?
The first place I saw this was in an early FET-input oscilloscope probe.
Unfortunately I can't recall the model. The idea is pretty simple, really:
in ------------->|--+
| |------ out
| c |
_|_ \ |
___ \|______
| e </ |
|__________|
| I
The capacitor is sized to steal enough HF energy from the input signal to
drive the next stage's input capacitance. Its inter-lead voltages never
experience any voltage change, so the device's capacitances never experience
any change in charge. Bootstrapping the drain is necessary, of course,
both to keep capacitive currents and thermals from wreaking their havoc.
Not shown, of course, is the input bias circuit. Since you're not interested
in dc this should make some aspects easier -- the bias can be servoed.
The current-source NPN can't be bootstrapped, to preserve the 'virtual ground'
seen by the low side of the input capacitor, but a souped-up variant could
be used in place of a simple/single NPN.
If you really don't need the impedance buffering, however, this may all be
pointless. You may have already tossed this, but perhaps you "only" need
to create a super-low-noise, stable sample-hold device, along with a somewhat
more traditional low-voltage-noise amplifier (with input protection). It
doesn't seem like you need the super-low Iin of the FET, do you? Of course,
such a sample-hold might be harder to build than the amplifier!
Good luck ... HTH...
-frank
