Input stage mess
Discussion in 'Electronic Design' started by Fred Bartoli, Nov 28, 2005.
  1. Fred Bartoli
    Fred Bartoli Guest
    Well, I've finally got doing that low noise preamp: the target is
    200pV/rtHz, bandwidth from 0.1Hz (with provision for 1/f noise) to 1MHz.
    Lots of interesting pbs to solve. One remaining thing is some stability
    issue wrt to cable/generator impedance.
    The input stage will be 4 to 6 paralleled Interfet's IF3602. They'll work at
    a low servoed 1V VDS to minimze thermal noise problems.
    Under those bias condition the JFet will show about 300pF Cgs and 180pF Cgd.
    The Jfet is servo-cascoded so that amounts to and equivalent 480pF Cgs.
    The closed loop preamplifier show an input impedance that has a painfull
    negative real part input admittance.
    Admitting a first order response, the input admittance is:
    Cgs w^2
    Yin = -------------- with WT = 2 pi GBW and beta= feedback network
    attenuation
    WT beta + j w
    This translate to an equivalent parallel network:
    2 2 WT beta
    Rin(w) = - ------------ - ------------
    Cgs WT beta Cgs w^2
    1 Cgs w^2
    Cin(w) = --- . -------------------
    2 w^2 + WT^2 beta^2
    Now the figures:
    designing for a 10 loop gain (WT beta) at 1MHz this give a low -12R for the
    real part at high frequencies and will give a nice oscillation with the
    input cable impedance (estimated between 300nH & 500nH).
    As the generator impedance is low, the easy way to deal with this could be a
    serie RC in parallel with the input (sort of 2-5 nF and under 12R resistor).
    Unfortunatly a 10R resistor is 410pV/rtHz and 41pA/rtHz which translates to
    about 130pV/rtHz across the 0.5uH cable inductance at 1MHz. A bit more than
    I would like.
    More, this 10R is dangerously close to the -12R value, which didn't
    accounted for additionnal parasitic poles and will probably be lower.
    Plus cable resonance with the input capacitance will rise the noise level.
    I can't insert a damping resistor in series with the gate connexion for
    noise reasons (200pV/rtHz is a super low 2.5R noise resistance).
    I've thought of a lot of schemes for neutralizing Cgs, but found nothing
    practical.
    I also can't run the input stage open loop, which would solve this issue but
    will raise some others.
    Any idea?
  2. John Larkin
    John Larkin Guest
    Can you post a schematic, real or simplified?
    John
  3. Mark
    Mark Guest
    add a C across the cable to resonant out the L.?
    I don't undestand why your cable looks inductave anyway?
    Is the source Z of the generator equal to the characteristic Z of the
    cable?
    The only way for the cable to look inductave is for it to be short
    length (probably true) and for the generator source Z to be lower then
    the cable characteristic Z.
    Is the cable charateristic Z 50 Ohms? Whats the generator, a low Z
    mic...is this for audio? Why go to 1 MHz?
    Mark
  4. Fred Bartoli
    Fred Bartoli Guest
    Here it is.
    85mA 85mA
    to to
    125mA 125mA
    V V
    | .-.R3 | .-.R4 | /| | | |\ |
    | | | 2 V |
    clamp --. | .-------------------' |
    | | | | | | ___
    | | | | | .---------------------|___|-.
    10u | J1 |-+ | +-|J2 | | | R2 |
    || | | | | | | ___ | |\ |
    in -+--||--+--->|-+ | +-|<-------+-|___|-. | .----|+\ |
    | || | | | | |5mA R1 | 5mA| | | >-+-out
    .-. .-. '---+---' | | GND | | GND .-|-/ |
    | | | | | | V V | | |/ |
    1M'-' '-'1G | | Precision |--+--||--+
    | | V | current mirror | .-.
    GND | 160mA '-----------------------' | |
    | to /| | |
    | 240mA /+|-GND'-'
    J1 and J2 are 4 to 6 paralleled IF3602, no source degeneration (noise),
    running at 20mA/transistor.
    R3 and R4 are one per transistor and 50R (1V across the Jfet, 1V across the
    R)
    The feedback path has _low_ impedance (1 fb path per jfet, 1R/27R).
    As you can see, nothing terribly fancy. All lies in the details (like the
    subject of this post).
    For the problem of interest here, it comes from the differential input
    voltage which rises 6dB/oct with a 90° shift wrt to the input voltage (due
    to the open loop gain pole) and the JFETs capacitances across the inputs
    (1.45nF between the preamp in+ and in-) which introduces another 90° shift
    for the current injected at J1 gate, hence the negative resistance.
    Exactly the same pb as an emitter follower loaded with a cap.
  5. Phil Hobbs
    Phil Hobbs Guest
    Hmm. Looks like the origin of the problem is the overall feedback. Do
    you really need the virtual ground? If not, how about making the input
    stage a feedforward 20-dB stage instead, and adding the feedback amp
    afterwards?
    Since your JFETs will be reasonably linear at that I_D, the feedforward
    path will have low gain, and hence you can use a higher-noise amp to
    generate it. This of course will require a bit of tweaking.
    BTW are the 10-uf capacitor leakage and gate current really low enough
    to use a gigaohm gate leak resistor-- 1pA ==> 1 mV? And do you really
    want a 3 hour time constant on your bias circuit? Oh, and you have two
    nearly perfect integrators in your dc feedback loop, which will cause
    nasty behaviour.
    Cheers,
    Phil Hobbs
  6. Frank Miles
    Frank Miles Guest
    [snip]
    Challenging!
    I don't know if you can meet the noise specs by going down this pathway,
    but if the series RC shunting the input adds too much noise, I think you're
    going to have to bootstrap your input circuit to get rid of the negative RC
    Zin. This will have to operate at high speed -- not at the slow speed of
    the feedback loop. Of course there are limits to this approach as well, but
    with the right topology you may be able to use a pure capacitance between J1's
    gate and an appropriate virtual ground input node to provide a high frequency
    boost to J1's source. This has been done, for example, in a few oscilloscope
    vertical inputs to provide a wider-band input while reducing the dribble-up
    behavior of real follower circuits which have capacitive loading.
    Did you say anywhere what the spec had to be for input capacitance? Perhaps
    a bit more HF energy can be stolen from the input? Some other games might
    be played if that is allowed. From your resistor values it looks as though
    Rin must be high.
    Unfortuantely I don't see any way to use the capacitive feed-beside method with
    your existing topology. It really needs a follower initial input stage.
    This fixes your Zin problem but reaching your noise target will be fun.
    I confess I haven't gone through the numbers to determine whether that is
    possible with such a different structure. Good luck!
    -frank
  7. John Larkin
    John Larkin Guest
    Why is the input stage differential? Seems to me that doing that
    increases the noise by 1.41 or something. And all those current
    sources look complex and potentially noisy to me.
    What are you using for the clamp? I have a similar problem... I need a
    pA leakage clamp that can swallow some 10s of mA overloads.
    John
  8. Fred Bartoli
    Fred Bartoli Guest
    Thanks Phil.
    Comments inserted below.
    Which virtual ground are you speaking about? The whole preamplifier is
    non-inverting.
    Hmmm, feedforward is one thing I forgot to think about. I can smell some
    interesting idea here but right now I fail to see exactly what you have in
    mind. Can you sketch something?
    One thing I can't do is getting the Jfets out of the feedback loop. The
    preamplifier will have 2 purposes:
    1) investigate noise in a _very_ low noise power supply (200nV rms)
    2) measure the supply transient recovery to an injected charge. The measured
    recovery is about 200nV, so expected aberrations (electric and thermal)
    should be lower than 50nV,... excluding noise :)
    Unfortunatly the initial transient can be a few 100mV, up to about half a
    volt, and will induce nasty thermal tails if the jfets were working open
    loop.
    Working with an hypothesis of 1mV/K offset gives 50uK for the stability, and
    200pV/rtHz translates to 0.2uK/rtHz, so some serious power stabilisation is
    in order there.
    I've measured some of the Jfets at under 2pA gate leakage under these
    conditions, much better than the given specs and this is for a few boxes, so
    that's OK for me. I was pleasently surprised because these are pretty big
    transistors and this will simplify my already enough complicated life.
    The 10uF are specified at 25000s minimum time constant, i.e. 2.5 gigaohm.
    The input DC component is about 10V and I've again measured some samples
    much better. Again I can select so it's OK too.
    And do you really
    An unfortunate side effect of the low frequency requirements.
    I've not shown some speed up circuitry which was not relevant to the pb.
    The 10uF is mandatory because of the gate shot noise rising the input noise
    at low frequency, and the bias resistor has to be 1Gohm because I obviously
    don't want its current noise be greater than the gate noise current.
    Oops, yes I obviously missed a zero somewhere :)
  9. Perhaps a resistor in series with the output opamp feedback capacitor
    could cancel one of those poles.
  10. Fred Bartoli
    Fred Bartoli Guest
    Yep. It indeed increases noise by a sqrt(2) factor and makes me double the
    Fets number to regain it... and worsens the negative resistance number by
    the same factor as a side effect :)
    Anyway some other problems make this a preferred solution:
    A single branch input stage will have to either have its source current
    provided by the feed back network (if one use feedback around it), or
    compensated with a current source.
    The preamplifier will have 2 purposes (and 2 modes):
    1) investigate noise in a _very_ low noise power supply (200nV rms). In this
    mode the diff input stages provide good rejection of the common tail current
    source variations. With a single sided input stage this noise will not be
    reduced.
    volt. I obviously can't have the lower feedback resistor (0.2R!) stand half
    a volt (and I want the power to be limited: low noise switching supply for
    the isolated input stages, low thermal convection noise and blah...), so in
    this mode, where I can average out the noise, the feedback network is
    switched to a more current friendly 100R/2.7K per transistor, which will
    represent a manageable total 20-30mA at 0.5V input.
    This feedback network obviously can't provide the 100mA transistor current,
    so a compensation current source would be required, with a too big impact on
    LF noise.
    Another pb for the single sided solution is that the source will have to be
    servoed at 0V (current in the 0.2R fb resistor) which will make the gate
    potential between -0.1/-0.5V, with potential leakage problems in the
    protection device.
    A few mV is all I can accept here.
    Yet another pb is the looong input time constant and the diff input stage
    will help slow thermal drift rejection.
    And... and...
    Probably something like this. As I can't have any series resistance, at
    least at the begining of an input event, the diodes will have to cope with
    high current pulses.
    V - |
    | +--------+-----> current limiting switch command
    V -
    GND GND
    And also probably some switched current limiting resistor (I can have a
    permanent one due the noise specs), because I have to protect the supply
    under test from the 10uF cap charge (and discharge).
    Unless I discover the miraculous depletion transistor with ultra high Gfs
    and low Idss.
    Maybe I can have my little daughter write this down on her letter to SK, but
    I guess she'll fell upset if I have that nice transistor and something else
    is missing.
    Do you know such a beast? :)
    Hmmm, the IF3601-02 I have measure 1.9ohm RDSon. Maybe I should look a bit
    further, but not too much hope...
  11. John Larkin
    John Larkin Guest
    How about a transformer?
    http://www.thinksrs.com/products/SR554.htm
    John
  12. Fred Bartoli
    Fred Bartoli Guest
    "John Popelish" <> a écrit dans le message de
    I don't know why but some messages I answer are not quoted so I have to
    manually add the quote sign, like below, to keep the message understandable.
    Anybody knows why?
    I've first thought of this, but this is just pushing up the GBW product and
    when the loop gain falls again, guess what...
    On the same note I've thought of limiting the gain in the pass band to have
    it uniform, like loopgain = constant (50) from LF to the corner freq. But
    the outcome is the same at HF.
  13. So where are the natural poles in this circuit, not counting the one
    at zero for the output integrator? I would put the zero at the lowest
    one of these poles. Setting this feedback zero would also probably
    include increasing the size of the integrator capacitor, to reduce the
    low frequency gain so that the second pole occurs beyond unity gain.
  14. Fred Bartoli
    Fred Bartoli Guest
    Yup. From the whole bunch of pb I could list I'm pretty safe to say that
    this is probably the limit of what's doable at room temperature.
    Hmmm, now that sounds interesting. That really is a clever trick, if I
    understood correctly what you meant.
    Do you have any specific scope reference or schematics to look at?
    Plus, in my case, the following current mirror and summing, neutralize this
    current injection (from the loop gain POV).
    Really nice!
    Not at all (well in AC). The source is low impedance (indeed, it is a low
    noise one).
    The (almost only) limiting factor is the cable series inductance, up to 1
    meter length requested, but I hope I can cut this by half.
    What other nice thing do you have in mind? I've made me curious :)
    For the high value resistors, as I explained in my answer to Phil Hobbs, the
    1G is there to achieve the specs at the low frequency end.
    The 1M at input is here because I expect to use its noise to check the
    connected-unconnected state and it is also a weak pulldown for the DC
    blocking cap. I also don't want current induced contact noise, so I reduce
    it to the minimum level.
    Maybe I can see some solutions.
    Time to check...
  15. Phil Hobbs
    Phil Hobbs Guest
    Well, your amp is going to take a long time to stabilize when you turn
    it on, just based on that 10,000 second time constant. With a 15V power
    supply, the bias loop will slew at (at most) 15 mV/s.
    If all you want is a noise measurement, you can use the correlation
    trick: put two amplifiers on it, and cross-correlate their outputs. The
    amplifier noise goes away and the true signal survives. Gives you a
    nice mean-square noise measurement. You can set the measurement
    bandwidth and integration time separately to get the measurement you
    need--e.g. you can measure the noise in 1 MHz bandwidth but integrate
    for 1 second, and get a 60 dB noise improvement.
    You can get rid of the thermal tails pretty well by biasing the JFETs at
    their peak power points.
    Alternatively, you might consider turning the problem inside out: use a
    normal op amp to do most of the job and use the JFETs to measure its
    differential input voltage, so that the *JFETs* are the feedforward
    path. If you can match the gains of two signal paths accurately, you
    can get the low noise of the JFETs and the stability of a normal op amp.
    The noise suppression you can get with that trick will be limited by the
    gain matching and phase shift between the JFET feedforward path and the
    normal op amp path.
    (Anybody done that before? I might have invented it just now.)
    Cheers,
    Phil Hobbs
  16. Fred Bartoli
    Fred Bartoli Guest
    I've seen it. Unfortunatly its nasty input impedance, 3R at 1Hz, 0.2R at
    0.1Hz, won't fit the bill.
    I wish it would. Well, in fact no: No pb, no contract... :)
  17. Fred Bartoli
    Fred Bartoli Guest
    I don't remember if I've already said this, but I have a fast settling mode
    to keep this time in the seconds area. The only unknown is dielectric
    absorption, but a quick check will say all.
    I remember you already mentioned this but we also want the spectral density
    repartition in order to be able to diagnose the causes.
    Already done. I also wish I could bias them at their temperature
    compensation point but the high current value render this impractical :-(
    Again I'm not sure I see all the details of what you have in mind. Can you
    elaborate?
    But wait... Hmmm, you're giving me another idea, or maybe the same, just
    pushed a bit further, or presented differently...
    If I reduce the overall GBW product I rise the resistance negative part and
    also reduce the maximum possible frequency of oscillation, hence increase
    cable inductance tolerance (is this enough, I'll have to check this point).
    Combined with feedforwarding the JFETs signal we could hold a good starting
    solution.
    Combining all this with a bandwidth limited (since we have ffwd) version of
    the Frank Miles' "source boost" trick to get rid of the last bit of negative
    resistance and it could well be a perfect match to what I looked for.
    I'll look into all that tomorrow. It's time to bed now.
  18. Mark
    Mark Guest
    Why do you need BW to 1 MHz to check a power supply output?
    Mark
  19. Fred Bartoli
    Fred Bartoli Guest
    Yes, why...
    Well, because... :)
    Seriously, because those power supplies are part of an ultra sensitive high
    definition, real time, video imaging system where some minor aspects of
    noise have huge impact on the image quality. Spatial and temporal coherency
    of noise, as sampled by the imager, is of primary concern and effects well
    below an LSB of the 16b ADCs are visible and annoying.
    And when the final customer pays $5M for one system he simply wants the very
    best quality :)
  20. Ken Smith
    Ken Smith Guest
    I've done things like that and have a couple of suggestions:
    note the points A and B.
    (1)
    If you add a switch and to switch in a lower resistance between A and B,
    you can get the circuit settled more quickly.
    (2)
    If you add a series RC from A to B you can add a zero to the bias point
    servo. You can use this to get rid of peaking at the gain cross over
    point.
