I was wondering if it is okay to feed a voltage lower than the set output voltage for a switching regulator like LM2576.
I'm trying to control the output at two terminals (18V and 12V) depending on the temperature sensed. The 18V output 1 is controlled through a PWM that regulates the voltage to 9V when a certain temperature is achieved. I want the 12V terminal to also switch to 9V (or slightly lower) at the same temperature. To do this, I wanted to avoid using a second PWM controlled regulator and was wondering if I could directly feed the first PWM output to an LM2576-12. During normal operation, it's input would be the 18V output of the first output which it will then convert to 12V. When the switching temperature is achieved, output 1 will go to 9V. Is it okay to feed this to the LM2576-12 to obtain nearly 9V at output 2.
