input capacitance opamp non inverting buffer
Discussion in 'General Electronics Discussion' started by jdavis6809, Jul 9, 2014.
  1. jdavis6809
    jdavis6809
    Jul 9, 2014
    hello
    using 2 non inverting opamp buffers (AD8620) to read the voltage across 2 resistors connected in series
    1 reference resistor and 1 resistor DUT via reed relays (reed relays are switched in turn to read each resistor)
    Output of opamp buffers feed an instrument amplifier AD8211
    The input of the buffer opamps are wired to the reed relays via 1k resistors in the air to minimize leakage
    All of the input circuit from the bnc's to the non invering inupts of the opamps are wired off board to minimize leakage
    I know how to offset the input cable capacitance by using a guard opamp
    the plan was to be able measure the impedance from 1m ohm to 100M ohm driven by 1vrms sine wave 100Hz to 100Khz
    I could not fine much information on the internet on how to neutralize the input capacitance for a non inverting opamp buffer
    impedance measurement up to 100K ohm ok
    thanks
    john
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    You don't actually say what your problem is, but I am guessing you are not getting the desired results you were after. It's really difficult to comment without seeing a circuit diagram. Please supply a clearly drawn circuit diagram with the following:
    1) List any measured voltages and label point where measured or print them on the drawing linked to the circuit point.
    2) List what you think they should be.
    3) Clearly define component indent's, i.e R1 C2 etc.
    4) Clearly define component name and value, example. 100R, 200uF, LM**** PIC18**** that sort of thing.
    5) List any formulas and workings you might have used to calculate component values if any.
    This really speeds up the response of someone trying to help.
    Cheers
    Adam
  3. jdavis6809
    jdavis6809
    Jul 9, 2014
    hello
    uploaded a circuit diagram (not complete just shows the front end)
    this from my simulator
    prototype has been built
    problem I have is when range resistor is above 1M ohm and DUT is same value
    output voltage should be the same but it is not due opamp input capacitance
    I have compensated for the bnc kelvin probe cable capacitance (guard amps)
    I want to know how to compensate for the opamp input capacitance
    frequency range 100Hz to 100Khz
    input voltage is 1v rms sinewave
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Great, let me have a look.
  5. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    You could try and place a small capacitor across each sense resistor, similar to how a scope probe works. You might only need these with the larger values of resistors. Also run the resistance measurement part of the LCR at a much lower frequency.
    Adam
