You're talking ATX form factor, but from the AT days:
Power is applied, all hard resets are accomplished. A program stored in
ROM runs, establishing communication of the motherboard's chipset. In
AT machines this BASIC boot program only ran in a few K of memory
(RAM). Newer machines now might automatically do what HIMEM.SYS used to
do, access all those MB of RAM through the first megabyte. That
program, which as I said used to be written in BASIC it writes to
actual EPROM in some cases, but usually stores the settings in RAM. If
the battery dies it reverts to the defaults in ROM or EPROM.
Usually all hardware devices are polled as soon as the boot ROM runs.
That's how it can setup the sectors and stuff on a new harddrive. This
is actually after the memory test, whether it indicates that on the
screen, or not.
It then checks all of the listed boot devices, in the order you set and
the OS on the disk takes over.
You can usually see the boot process when you get the BIOS splash
screen saying, like Dell or something, by hitting the Esc key. You may
see it counting the RAM.
The EXACT process for any given motherboard differs, but it almost
always checks the RAM first, then polls all the hardware, unless it is
not a PnP machine or Pnp is shut off. Modern machines seem to always
check the HDs, before PnP you could not just stick a HD in a machine
and have it work. You needed to set the heads, tracks, cylinders, crap
like that.
From the Pentium days hence, there are also some very basic CDrom
drivers in the boot to make it possible to boot from CDrom.
In the AT machine when it was off it was off. In an ATX when you ground
the green wire you trigger a change of states in the ATX power supply,
which supplies a few standby sources all the time. When it goes into
the "ON" mode the regulation is tighter and all the run supplies are
switched on. The standby is only there to allow wake on LAN or ring,
and like some PCs you can turn them on by hitting the spacebar.
That's about as technical as I can get. Sorry no URLs. (except this one
you're in I guess)
JURB
