infrared linear actuator
Discussion in 'Sensors and Actuators' started by tangledtangent, Mar 5, 2013.
  1. tangledtangent
    tangledtangent
    3
    Mar 3, 2013
    i don't know if you could help me but here it goes. I am trying to get a linear actuator controlled by an infrared transmitter & receiver like shown in this clip:
    . The infrared transmitter will emit a modulated signal to the infrared transmitter which be connected to the linear actuator as well as a microprocessor (preferably the basic stamp) & that will command the actuator to do a certain action (in this case, it's just simply descending & ascending). Another clip here shows an actuator controlled using arduino I believe: http://www.instructables.com/id/Standing-Linear-Actuator-powered-by-Modtronix/ . But the biggest problem for me is setting up the circuits for the infrared transmitter & receiver, since I'm not exactly sure of which components to incorporate...this circuit right here shows what components to use but I don't know how to set it up on a solderless breadboard:
    http://www.electronicsforu.com/efylinux/circuit/may2003/ci3-ir-remote.pdf . Anyone got any tips on how this can work?
  2. Electrobrains
    Electrobrains
    259
    5
    Jan 2, 2012
    Do you plan to build your own transmitter or do you want to use an existing remote control unit?
  3. BobK
    7,682
    1,688
    You can get 3 pin IR recievers that would replace everything up to the transistor and relay at the output of the circuit you have linked.
    Here is a tutorial on them:
    http://learn.adafruit.com/ir-sensor
