infrared 4013 flip-flop
Discussion in 'General Electronics Discussion' started by dam_13_n, Apr 16, 2011.
  1. dam_13_n
    dam_13_n
    Apr 16, 2011
    Im trying to build a robot that will take a right then a left and so on via, infrared remote and im using a basic on/off circuit with a 4013 flip-flop and it won't lock on an scr wich is goin into a relay. the pulse is coming out, i know this because i put an indicater light on it. the relay has a stronger resistance on the NC with a diode and a regular resistor on the NO so one wheel will go slower if i can get the scr to lock on.
    its a single pole double throw relay
  2. (*steve*)
    25,404
    2,777
    How about you draw the circuit diagram for us, then explain the problem with reference to it.
