Information on gal
B
banu
Hi all,
can anyone help me regarding how to load the gal program in
to the gal chip,without using the gal programmer.
Earlier reply is appreciated.
Regards,
banu
R
Rene Tschaggelar
banu said:
Hi all,
There usually is a datasheet that also explains how to program
whatever part. Meaning it enables you create your own programmer
for the part in question.
If not, have a look at the device family datasheet.
Rene
M
Mike Harrison
This is rarely true for programmable logic parts (except ISP ones), specs can be somewhat hard to
come by.
M
mike
banu said:
Hi all,
Regards,
banu
Not possible.
Anything you build to load the program is by definition a gal programmer.
Back in the early days, the progarmming algorithms were published in
the databooks. The National PAL databook from 1982 contains such info.
I expect this was a support nightmare, cause they soon stopped
publishing the data.
Be aware that different vendors and different versions of the same part
had different programming algorithms.
You'd get more targeted answers if you disclosed the actual vendor and
part number.
mike
laptops and parts Test Equipment
4in/400Wout ham linear amp.
Honda CB-125S
400cc Dirt Bike 2003 miles $550
Color LCD overhead projector
Tek 2465 $800, ham radio, 30pS pulser
D
Dr. Anton Squeegee
banu1118 said:
Hi all,
Won't happen. GALs, and other PLDs, are not at all like memory
devices in their programming algorithms. Exceedingly complex, and very
finicky about programming waveform shape and timing. To make matters
worse, programming algorithms for some PLDs can change in less than a
week, depending on if the device's manufacturer decided to "improve"
something.
In short, you need the proper programmer. Period. I offer
programming services, if you have the JEDEC file that you need to
program in. I can also supply the actual parts if it's not something
that's been discontinued.
http://www.bluefeathertech.com/devices.html
