info request for C4235 bipolar transistor
Discussion in 'Electronic Components' started by Hugh_h PL, May 17, 2004.
  1. Hugh_h PL
    Hugh_h PL Guest
    it has labels as follows
    2n
    c4235
    and its not the 2n4235, it is in TO220-like package but wider, I got
    it from old mono PC monitor, any idea abou parameters or counterparter
    thanx
  2. Hi,
    It is probably a -
    2SC4235 (Si, NPN)
    Vcbo(max) = 1200V
    Vceo(max) = 800V
    Ic(max) = 3A
    Ptot(max) = 80W
    Tj(max) = 150C
    Icbo = <100uA @ Vcbo(max)
    HFE(min) = 8 @ Ic = 1.5A/Vcb = 5V
    fT = 8MHz
    Lead-out = BCE (Collector isolated)
    Cheers - Joe
  3. Hugh_h PL
    Hugh_h PL Guest
    ok thanks for then param info,
    anybody knows good replacement for it from popular transistors?
  4. original data sheet:
    http://semi.shindengen.co.jp/en/2sc4235.pdf
    If the 2SC4235 is used as horizontal output transistor in a TV-set
    BU2525A or maybe BU508A should work fine.
    Regards,
    Dieter
