Info on the lastest "Hot Cat" LENR
Discussion in 'Home Power and Microgeneration' started by amdx, Aug 12, 2012.
  1. j
    j Guest
    I don't understand the temperatures.It appears that the outside of the
    device is at 800C
    Cures has stated that at the time of the photo, the average external
    temperature of the module was E-Cat was 801 degrees Celsius, with a peak
    local temperature of 873C in one spot. This was recorded by the infrared
    camera. The temperature of the inner surface was measured (with the
    handheld laser themometer) to be from 1,100C to 1,200C, increasing in
    temperature towards the center of the module.
    However, that should be bright red:
    http://www.threeplanes.net/toolsteel.html
    It doesn't look right to me,but I simply don't know.
    Jeff
  2. j
    j Guest
    In addition, they calculate heat output at 13.39kW
    That is 45.6K BTU
    That is a lot of heat for the small office that this appears to be run
    out of. Nearly 4 tons of AC for one room.
    The heat output figures just don't make sense to me.
    I also roughly calculated the surface area required to yield 45K BTU at 800C
    http://docs.engineeringtoolbox.com/documents/431/heat_radiation_from_black_surface_absolute_zero.pdf
    http://www.engineeringtoolbox.com/radiation-heat-transfer-d_431.html
    and it is ~ 1.75 SF
    The surface area of the pipe looks closer to a sixth of that.
    I happen to think LENR is doable, but this doesn't seem right. The heat
    output figures seem doubtful. It seems to me closer to the heat input.
    Jeff
  3. Jim Wilkins
    Jim Wilkins Guest
    This shows how to judge high temperature from the color of the glow:
    Room lighting affects your color perception.
    jsw
  4. News
    News Guest
    PESN reports whet is there, and is the first to castigate when a hoax or
    scam is involved.
