infix to postfix negation
Discussion in 'Microcontrollers, Programming and IoT' started by lady_krizzie, Sep 18, 2012.
  1. lady_krizzie
    lady_krizzie
    30
    Aug 2, 2012
    I am trying to make a calculator program. But I have a problem with the negative sign. I fixed the program to do expression of (0-5)+12 if I want 5 to be negative. But I want and I am expecting it to do -5+12 Please help...Thank you in advance.
    Code:
    #define MAX_CHAR 64
    #define LP 10
    #define RP 20
    #define OPERATOR 30
    #define OPERAND 40
    #define UNARY 50
    #define LPP 0
    //#define LPP 1// Left parentheses precedence. Minimum of all
    #define RPP 1
    #define AP 2// Addition Subtraction precedence. Minimum among all operator precedence
    #define SP AP
    #define MP 4// Multiplication divisor precedence.
    #define DP MP
    #define REMP 2// Remainder precedence.
    #define NONE 9
    char input_string[MAX_CHAR] = {};
    char out_string[MAX_CHAR*2]= {}; //input_string
    char bufer_string[MAX_CHAR] = {};
    double stack_string[MAX_CHAR] = {};
    char *next;
    int input_index = 0;
    int bufer_index = 0;
    int stack_index = 0;
    int foo = 0;
    int isanumber = 0;
    int num = 0;
    //int num = 0;
    int error = 0;
    void infixtopostfix(void);     /** POSTFIX CONVERSION FUNCTION **/
    int gettype(char);             /** TYPE OF EXPRESSION GENERATOR **/
    void push1(char);               /** PUSH FUNCTION **/
    void push2 (int);
    char pop1(void);                /** POP FUNCTION **/
    int pop2 (void);
    int getprec(char);             /** PRECEDENCE CHECKER FUNCTION **/
    int getValue(void);
    	int i,p,l,type,prec;
    	//char next;
    	i=p=0;
    	l=strlen(input_string);
    	while(i<l)
    		type=gettype(input_string[i]);
    		switch(type)
    		case LP:
    			push1(input_string[i]);
    			break;
    		case RP:
    				//while((next=pop1())!='(')
    				//out_string[p++]=next;
    				out_string [p++]= ' ';
    				out_string [p++]= pop1();
    				pop1() != '(';
    			break;
    		case OPERAND:
    			out_string[p++]=input_string[i];
    			break;
    		case UNARY:
    			break;
    		case OPERATOR:
    		default:
    			out_string[p++] = ' ';
    			prec=getprec(input_string[i]);
    			while(stack_index>-1 && prec <= getprec(stack_string[stack_index]))
    				//out_string[p++] = ' ';
    				out_string[p++]=pop1();
    				out_string [p++] = ' ';
    			break;
    		i++;
    	while(stack_index>-1)
    	out_string[p]='\0';
    int gettype(char num)
    	int i,p;
    	i= 0;
    	switch(num)
    		case '(':
    			return(LP);
    		case ')':
    			return(RP);
    		case '*':
    		case '/':
    		case '+':
    		case '-':
    			if ((input_string == OPERATOR) || (input_string == '\0') && (input_string== '-'))	//a minus sign followed by a  or null is a unary
    				return (UNARY);
    			else
    				return (OPERATOR);
    		case '%':
    		case '\t':
    			return(OPERATOR);
    		/*case '-':
    			return(UNARY);*/
    		default :
    			return(OPERAND);
    void push1(char num)
    	if(stack_index > MAX_CHAR)
    		printf("\nStack is full\n");
    		exit(0);
    	else
    	stack_string[++stack_index]=num;
    char pop1(void)
    	if(stack_index<=-1)
    		printf("\nStack is empty\n");
    		exit(0);
    	else
    	return(stack_string[stack_index--]);
    void push2(int num)
    	 if (stack_index > MAX_CHAR)
            printf("error: push to full stack\n");
            error = 1;
        else
            stack_string[stack_index++] = num;
    int pop2(void)
        int retval = 0;
        if (--stack_index < 0)
    	//if (stack_index<=-1)
            error = 1;
            printf("error: pop empty stack\n");
    		//exit(0);
        else
            retval = stack_string[stack_index];
            stack_string[stack_index] = '\0';
        return retval;
    int getprec(char num)
    	switch(num)
    		case '(':
    			return(LPP);
    		case ')':
    			return (RPP);
    		case '*':
    			return(MP);
    		case '/':
    			return(DP);
    		case '+':
    			return(AP);
    		case '-':
    			return(SP);
    			//return(UNARY);
    		case '%':
    			return(REMP);
    		default :
    			return(NONE);
    int getValue(void)//return an integer input.  next points to first digit
    {					//allows a negative answer, second digit or operand is lesser than the first operand
    	int value = 0;
    	while(isdigit(*next))
    		value = 10 * value + *next - '0';
    		++next;
    	return value;
    int main (void)
    	USART_Init(51);
    	stdout = &uart_output;
    	stdin  = &uart_input;
    	char choice;
    	int r; // repeat
    	char garbage;
    	int bar;
    	int ch;
    	do
    		stack_index=-1;
    		printf("\nEnter an infix expression\n");
    		scanf("%[^\t]s", input_string);
    		infixtopostfix();
    		printf("\ninfix = %s\npost fix =%s\n",input_string,out_string);
    		bar = 0;
    		while(bar < strlen(stack_string))
    			stack_string[bar++] = '\0';
    		stack_index = 0;
    		input_index = 0;
    		while (input_index < strlen(out_string)) //while operand is not reach
    			bufer_index = 0;
    			if (isdigit(out_string[input_index]))
    				isanumber = 1;			//a digit is found
    				for (foo=input_index; foo<strlen(out_string); foo++)
    					if (isdigit(out_string[foo]))
    					bufer_string[bufer_index++] = out_string[foo];
    					else
    					break;
    				input_index = foo + 1;
    			else
    				isanumber = 0;
    				bufer_string[bufer_index++] = out_string[input_index++];
    			bufer_string[bufer_index] = '\0';
    			if (isanumber)
    				// if element is a number, push to stack
    				//push(bufer_string);
    				push2(atol(bufer_string));
    				asm volatile ("nop"::);
    			else
    				// if not a number, check if valid operator
    				switch (bufer_string[--bufer_index])
    					case '+':
    						push2(pop2() + pop2());
    						break;
    					case '-':
    						if (isdigit(*(next + 1)))
    								++next;
    								push2(-getValue());
    						else if ('-' == UNARY) // unary operator
    								push2(pop2() * 1);
    						else
    							num = pop2();
    							push2(pop2() - num);
    							break;
    					case '*':
    						push2(pop2() * pop2());
    						break;
    					case '/':
    						if (num != 0)
    								num = pop2();
    								push2(pop2()/num);
    								printf(" ");
    								push2(pop2() * -1);
    						else
    								num=0;
    								printf("MATH ERROR \n");
    						break;
    					case '%':
    						num = pop2();
    						push2(pop2() % num);
    						break;
    					default:
    						break;
    				bufer_index++;
    			// check for error
    			if (error == 1)
    			break;
    		if (error == 0)
    			printf("\nAnswer: %d", pop2());
    	printf("\nNew Operand [y/n]");
    	if(choice=='y'||choice=='Y')
    	scanf("%d" , &r);
    	while( (getchar()!='n') && (getchar()!='N') );
    		return 0;
  2. dahhal
    dahhal
    58
    Jul 17, 2012
    would a quick hack would be to detect that the first character is an - and to add 0 in front of it.
    this wouldn't work well for when you + and - number like 5+-2. though this could be solved by another routine that looks for double operators ++, +-, -- and to change it to + -, and + respectively. This could all occur before your current code.
  3. lady_krizzie
    lady_krizzie
    30
    Aug 2, 2012
    Thank you.. Im going to think of it...
Similar Threads
Loading...
