E
Eeyore
"Vacuum" is a word that is not very well defined in public use.
sci.electronics.basics is NOT a place to ridicule people who ask beginner
questions.
"Troll" is a word that has no meaning.
John said:What don't you understand about "about"?
I believe it to be an inert gas too.
Did I miss something?
jasen said:cyanide,
jasen said:no, it'll be a partial vacuum.
Bye.
Jasen
Nitrogen is NOT an inert gas.
questions.
Bob said:"Inert" in this context refers to the reactivity of a given
material in the specific application in question. In the context
of the original question - the gas used to "fill" light bulbs and
such - nitrogen IS essentially inert. Not as good as argon,
perhaps, but it would serve the purpose and that's all the original
poster was asking about. Then we got off on this utterly
meaningless thread which served no purpose other than allowing
a number of people to demonstrate that they knew what "noble
gas" meant, and presumably to get whatever ego boost they
needed from showing off that knowledge.
Nitrogen is used in many industrial applications because it
IS, in a practical sense, "inert" in those applications (i.e.,
far, far less problematic than oxygen or normal air in those
cases). That's all that was ever intended here, so what say
we all let it drop rather than continuing to play these idiotic
sophomore-chem-class word games, OK?
If Phil Allison is going to use a chemical term incorrectly, then Phil
Allison is going to get corrected.
in·ert P Pronunciation Key (n-ûrt)
adj.
Unable to move or act.
Sluggish in action or motion; lethargic. See Synonyms at inactive.
Chemistry. Not readily reactive with other elements; forming few or no chemical
compounds.
Having no pharmacologic or therapeutic action.
Phil was correct.
Graham
Phil was not correct.
The dictionary definitions do not apply, because Phil used the words in a
phrase "inert gas" that CHEMISTS use as a substitute for the royalist phrase
"noble gas".
No matter what the words mean individually, the phrase means
Argon, Krypton, etc..
Furthermore, even using the dictionary definition, nitrogen is reacts with
many elements to form many compounds.
Hey, check out Larkins schematic on a.b.s.e!
But Nitrogen isn't very inert. It forms bonds with many elements. There is a
reason that they call Argon, Krypton, etc. the "Noble Gases", they don't
form bonds very easily.
"noble gas". No matter what the words mean individually, the phrase means
many elements to form many compounds. That FACT was illustrated in my second
post by a "short list".
