Jamie Morken
I wound a test inductor using litz wire and a ferrite core, one layer of
wire on the bobbin, now I realize there is still enough room for adding
another layer of wire. I would like to keep the same number of turns,
is it ok to wind the next layer on top of the first, in parallel with
the first layer? The reason I ask is the second layer will have a wider
loop of copper, and thus a longer path length of wire, so if I attach
the ends of the first and second layer in parallel, the DC resistance of
the outer layer will be higher, so I don't know if this will cause a
lower Q in the inductor. The other option is wind two strands at once
and then make a second layer with these, but that requires insulation
between the first and second layers.
cheers,
Jamie
cheers,
Jamie
