Inductor question
Discussion in 'General Electronics Discussion' started by Kari, Apr 9, 2014.
  1. Kari
    Kari
    10
    Apr 2, 2014
    So I was curious, what would be the result of winding an inductor around itself multiple times? As in at the end of the first coil, you wind the enameled wire back up around the coil and then down again several times? I don't really expect it to do anything out of the ordinary, just curious for a more seasoned hobbyist/professional's opinion.
  2. BobK
    7,682
    1,688
    Inductors are normally wound that way. The inductance is proportional to the square of the number of turns, so adding 1 layer to a 1 layer winding gives you about 4X the inductance.
  3. Kari
    Kari
    10
    Apr 2, 2014
    Neat! So could you essentially create a supermagnet with a 9 volt battery?
  4. BobK
    7,682
    1,688
    Magnetic field is proportional to the number of windings and the current.
    More windings = more resistance = less current, so it is not that simple.
  5. Kari
    Kari
    10
    Apr 2, 2014
    So then the only way to make the magnet more powerful would be to increase voltage assuming resistance is constant?
    Or are there other ways to increase current
  6. BobK
    7,682
    1,688
    More windings will increase the magnetic field if the same current is used, more current will increase the magnetic field if the same number of windings are used. The voltage needed to supply a given current depend on the resistance, which depends on the length (and inversely on the diameter) of the wire. More windings means more length, means more resistance. You can play with all of these things to increase the magnetic field.
  7. Kari
    Kari
    10
    Apr 2, 2014
    was assuming there was already a multi layer inductor with a fixed number of windings, so constant resistance :p
  8. duke37
    duke37
    5,364
    771
    Jan 9, 2011
    You can play with the wire thicknes and number of turns but to get the same magnetic field, you will need the same power.
    Get as much copper in there as is possible, if this is not good enough, use silver or a superconductor.
  9. Kari
    Kari
    10
    Apr 2, 2014
    Perhaps someday i'll attempt something just for fun, like a big hollow inductor filled with metallic hydrogen.
