Inductor Question
Discussion in 'Electronic Design' started by Don, Jul 17, 2003.
  1. Don
    Don Guest
    I have instructions to make a 14uH inductor for audio using the following
    data:
    Wind 20 turns of 20 gauge wire onto a 10 x 30 mm rod.
    Now if I use 22 gauge should I increase or decrease the amount of turns?
  2. I'm guessing that the "rod" is ferrite - otherwise you come up with about
    1.3uH with an air or plastic core.
    There is almost no difference between the inductance provided by the two
    gauges. Getting the specified ferrite rod is far more important. Ferrite
    variations and winding technique will provide more variation than the change
    in wire guage - so don't sweat it.
    Your audio capacitors might have 10 percent tolerance, so it doesn't
    matter - just wind your coil.
    best wishes
    Roger
  3. Dr. Bob
    Dr. Bob Guest
    It has to be a ferrite rod. You didn't specify. I assume this is for a
    crossover and therfore low resistance is warranted. If I were doing it, I'd
    wind bifilar two #22 giving the equivalent of one #19. This is lower
    resistance than one #20 but closer to the original than a single #22. The
    inductance will be slightly different but would have to be measured for
    certainty. For a crossover it won't matter.
